charge air circuit test
Old Jan 29, 2003 | 06:31 PM
cowpie's Avatar
For anyone interested in finding out if they have small leaks in their charge air system, I fashioned a homemade pressure setup that allowed me to pressurize the system from the turbo to the intake. I found three small leaks I didn't know I had and improved my max boost from 28# to 32#. I used a 4" threaded PVC plug, drilled and tapped it for an airline fitting and connected my pressure regulator to it. I put this in the intake hose where it comes off the filter box/BHAF. Then just pulled the hose off the intake manifold and used a 4" rubber screw-type plug in the hose. Word of caution: the breather hose from the filter won't take more than 20-25# of pressure before it blows the plug out This was plenty of pressure to listen for and locate leaks.
Old Jan 30, 2003 | 02:48 PM
Bart Timothy's Avatar
Re:charge air circuit test
It's not neccessary to pull the hose off the intake manifold to pressure up the intake system. Even using a small compressor, any air leaks inside the engine are easily over come. This also checks for intake manifold leaks which are common with the intake plenum plate and horn on 24vs.<br><br>You can build a system pressure checker for under $10 which connects directly to the intake of the turbo and allows for pressure checks up to 50 or 60 lbs.
Old Jan 30, 2003 | 10:00 PM
cowpie's Avatar
That sounds alot more efficient. Why do you not lose air through the valves and out the exhaust?
Old Jan 30, 2003 | 10:09 PM
[quote author=cowpie link=board=7;threadid=10255;start=0#98617 date=1043985608]<br>That sounds alot more efficient. Why do you not lose air through the valves and out the exhaust? <br>[/quote]<br><br>There's no valve overlap in the CTD.
Old Jan 31, 2003 | 11:55 AM
MSchoenheider's Avatar
I just built one for $6. Go to Home Depot and get there 4&quot; metal pipe plug. It has two metal platess and a rubber gasket thing inbetween them. As you tighten the bolt, the gasket is pushed outwards and seals any cicl from about 3.75 up to 4.25 inches. Drill a 1/2&quot; hole in the outside steel plate and put in a tire valve stem. drill a couple of holes in the bottom plate to let the air through. Wou may have to grind a little off the edge of the rear plate to clear he turbo inlet inner diameter, but no big deal. Oh yeah, you will also have to replace the wing nut that comes with the plug with a normal nut for clearence of the valve stem. I would put a picture of mine up, but I let a friend borrow it and won't have it back for a week or so.<br>Mark<br>
Old Jan 31, 2003 | 07:23 PM
cowpie's Avatar
Thanks for the info. As usual, there is always someone on this board with a better idea that makes my life easier. <br>No doubt I'm behind the curve on this one too, but I found the cure to my chronic leak problems around the hose-to-tube connections to be permatex adhesive gasket spray. Seems to work like a champ.
WhyKnot
Sep 9, 2010 09:20 AM
CaledoniaOutlaw
Jan 30, 2009 10:13 PM
Joe Diesel
Nov 12, 2007 08:59 AM
Haulin_in_Dixie
Jan 5, 2004 12:53 PM
cowpie
Jan 13, 2003 11:59 PM
