CB'S
CB'S
thinking of getting a cb. was thinking either uniden or cobra. i dont need anything real crazy, but the more power the better right ;D anyway, any suggestions on mdels or other makes ?? thanks guys, scott <br><br><br>o yeah ill need an antenna,suggestions and antenna mount also cb mount
Re:CB'S
Here's one place to look<br>www.exportradios.com<br><br>It'll give you an idea about what's available.<br><br>The other is check your local Yellow pges for a CB/Electronics shop in your area.<br>(Not Radio Shack or Circuit City)
Re:CB'S
Never have been a CB'er but I am a ham. Power is OK but if you want performance get the best antenna you can afford. Then get it tuned with a SWR as close to zero as you can on the frequency you will be using the most. I prefer a roof mount as this gives me a good reflector etc. Make sure the feed line is properly gounded at BOTH ends. Use quality feedline and quality connectors.<br>As for types and brands, you will have to check with the CB'ers.<br>
Re:CB'S
I have a uniden CB and it has doen fine for me. It was the smaller vershion but I have found it to be very easy to place in my truck and it is easy to reach when I need to turin it on/off or use the mic.<br>DM01
Re:CB'S
Cobra is the choice of many truck drivers they make a good radio...I have a Cobra with weather band its very usefull when traveling...a power mic helps with moduation...its best to buy from a local cb shop Ive found if you buy from a local shop they will tune your SWR free
Re:CB'S
Uniden Grant XL do'n 50 watts!
;D<br>Wilson 1000 Magnent Mount<br>Galaxy "tennis shoes"<br><br>Aaron you need to find someone with a SWR meter cause that radio sounded like
man
man
Re:CB'S
[quote author=Got Smoke? link=board=7;threadid=12370;start=0#117358 date=1047969448]<br>Uniden Grant XL do'n 50 watts!
man
<br>[/quote]<br>Well why don't you bring one up with you when you have to drop off your stacks.
<br>O and where the heck have you been? >
<br>Wess has not got a hold of the stickers for R&R but will have them soon.
man
