CB Antennas
Re:CB Antennas
Well after careful consideration I think I'm going to buy one of these and get a magnetic antena to use when I travel.<br><br>Cobra CB<br><br>I got to looking and there just aint a whole lot of room in the cab for a CB and this thing will mount under the center seat out of the way. 8) They say the mic isn't very loud so I might by an external speaker to help that out.
<br><br>Anyone here have one of these little units? Do they work pretty good or are they junk?<br><br>Thanks for the help.<br>DB
Re:CB Antennas
Hay you guys use whatever antenna's you want but the K40 is about the best one out there, an as for mounting it in the bed on the tool box worst locale it can be (find another place for it) you will be happier<br> Bob
Re:CB Antennas
If you are not trying to reach Argentina on your CB and want a rather inconspicous antenna, try the thru glass unit from Radio Shack. Now, I know the big boys will want to tell me how much loss I will have with this installation, etc etc etc. Well, this installed with a SWR of 1.05 and I am reaching very satisfactorily with a good signal with the small mini Radio Shack unit. My modulation is hitting better than 40%. That's not bad with a tiny radio like that. It is mounted on the knee panel under the steering wheel, easy to see and get at, sound is on my side of the vehicle away from the CFO who does not appreciate the language and is not in the way. <br><br>I mounted the antenna on the rear window. It is really easy to pull the wire along a floor channel just inside the door on the 2003. Nice neat installation, inconspicous, quick, easy and servicable. Cost of antenna is $40. <br><br>Bob
Re:CB Antennas
Here's one fur yah. Where is the best place to mount the antenna if you haul a 5th wheeler? I don't want to cut a hole in the roof for the antenna and I really don't like the looks of the front fender mount? I have been holding off for 3 months trying to come up with a place to mount the antenna that still looks good and gives a good signal. Any ideas?<br>Hauler
Re:CB Antennas
Get one of these.
Place to mount the antenna, a set of "Loading Lights", and whatever.
Better pic. to give you an idea.
http://www.jailgate.com/headache.htm
Re:CB Antennas
Hauler,<br><br>I'm in the same situation and have pretty much decided on going with a good Wilson or K-40 magnetic antenna.<br><br>The mag mounts offer a a good balance of form and function. The guys at our Radio Shop at work recommended the mag mount for my application. Also, the best mount surface is the very center of the roof.<br><br>The mag mount allows you the flexibility of putting the antenna behind the seat when you don't need it ... parking garages, car wash, etc.
Commatoze
Jan 4, 2003 06:25 PM
