Cab clearance lights ?'s
First off where's the best place to buy these lights? i know i can go through the dealer, but $80 seems a little high. also, does any one have the template laying around after installing them on your truck? thanks .
Re:Cab clearance lights ?'s
YEAH I NEED THESE LIGHTS TO....THE DEALER SAID TO DO IT THE COST WOULD BE 275 DOLLARS [eyecrazy]
Ive seen posts on this before - they said that the lights from the dealer are a complete set and are of very good quality - while some of the aftremarket kits are not complete and are of questionable quality.
If I could easily take mine off and fill the holes Id let ya have mine - cant stand the things. |
Yeah me too ...My dealer wanted $250 installed. I wonder
if the factory wiring harness is behind the headliner ?. Let me know what you guys find out. Thx, 03CTDCO |
I'd like to have some to let my know PLEASE ;D
I bought a set for my old truck and they were like $50 or $60 from a local aftermarket shop (who also installed them). If your doing the install yourself, I would probably just get them from the dealer for $80.
Tony |
There are factory sets on e-bay all of the time.
so i guess the factory ones arent too much over priced?!
We just put the factory lights on mine about 2 months ago, and with the template it is not hard at all. The kit from DC comes with everything you need to install them. Took my brother and I about 1.5 hours from start to finish. Take your time and be careful with the headliner, you only need to drop the front of it to wire the lights. And no, the harness is not already tucked in behind the liner.
Tiny |
tiny, sent you a pm.. i hink i may just go the dc way since it comes with everything including the template.
Tiny, How did you run the wiring up to the headliner ?
Any suggestions ?...How about the hole size you drilled thru the top of the truck ?..what diameter and did you prepare the exposed metal so it wont rust ? Thx, 03CTDCO |
I got the kit from DC as stated, and it came with all the lights, the harness, the plugs for the holes you drill, the template, the screws, everything but the bulbs. If I remember correctly, the bulbs are 194s.
To pull down the front half of the headliner, you have to remove both A pilars, visors, grab handles, and the quad latch covers. Be careful if you have the overhead display, that you move the wires out of the way prior to drilling. Tape the template over the windshield, use a punch to mark your holes, remove the template, and start drilling. We used a stepped bit, which is an amazing little tool! If you do not have a stepped bit, drill a pilot hole then drill the larger holes. Install the grommets that came with the kit, feed wires through hole, install plugs to screw into, insert bulbs into receptacle, plug receptacle into the light, and screw light onto roof. Now go inside, spread the harness from side to side, complete the wiring connections, and run harness wire down the driver side A pillar, and tie into light switch. Reinstall headliner and accessories, turn on lights and enjoy. Tiny |
Hmmmmmmmmmmmmm, sounds like you left out the part about crackin a beer open, i think at least 2 beers is required before one starts to drill holes into their truck..... thanks for the insight on the install tiny.
I think Dodgeboy59 added the lights to his truck. You may want to contact him.
It couldnt be very hard to do. Plus save you a ton of money for more high performance goodies. |
