Bypass for Walbro
Old Oct 15, 2006 | 06:16 PM
george7941's Avatar
Bypass for Walbro
I just went to the Glacier site to order a GDP Bypass Valve and they are out of stock on it. Is there somewhere else where this bypass valve can be purchased?
Old Oct 15, 2006 | 10:10 PM
GSP's Avatar
GSP
Ive searched and searched and havent found one like what glacier uses. I called that new walbro kit company AFS, and he doesnt have any seperate to sell either. He said his is made by Simflo. Searched the internet and the Simflo co I found never heard of it. So maybe its a different Simflo.
Im still searching. Seems like a simple valve. Glacier said he wanted $70 for the valve seperate.
Old Oct 16, 2006 | 07:05 AM
Mglass1045's Avatar
Keep us updated on that. I was looking around their site and couldn't find one either. What about a regular pressure regulator from somewhere like Summit or Jegs? A lot of them have a bypass return to the tank, and you'd be able to fine tune the pressure........?
Old Oct 16, 2006 | 07:52 PM
george7941's Avatar
The regular fuel pressure regulators at Summit are all meant for carbureted engines and they regulate the pressure to around 7psi, too low for our needs.
Old Oct 16, 2006 | 07:55 PM
piperca's Avatar
Mallory 4307M is adjustable from 4-25 psi and has a bypass. If you shop around you can get it for around $80.
Old Oct 17, 2006 | 08:38 PM
mbfarms's Avatar
If you are looking for a picture of the simflo regulator check out www.wideopendiesel.com/page8.html. It is toward the bottom of the page.
Old Oct 17, 2006 | 11:04 PM
piperca's Avatar
That's good to know, I had no idea that AFS were offering the regulator on its own ... good stuff!
Old Oct 18, 2006 | 07:18 AM
george7941's Avatar
I checked out wideopendiesel too and their prices seem more reasonable than Glacier's. Glacier is definitely pricey.
Old Oct 18, 2006 | 05:14 PM
george7941's Avatar
I was wondering if the Simflo regulator worked well and had the capacity to handle the output of the LP. Would someone confirm that they have used the Simflo regulator and have had good results with it. Thanks.
Old Oct 18, 2006 | 06:14 PM
piperca's Avatar
I am using it with much success. It is adjustable and easily handles the flow from the Walbro.
Old Oct 18, 2006 | 08:19 PM
mcctho21's Avatar
Try this site. www.swagelok.com When Superduty was around this is what he used. I run the one from Glacier but this was my next option.
Old Oct 20, 2006 | 04:38 PM
mbfarms's Avatar
george7941 my friend has a Simflo regualtor on his truck and it works very well. Very easy to adjust too.
Old Oct 20, 2006 | 08:49 PM
TNfarmboy's Avatar
I used a Hilborn checkvalve for the bypass. I called and asked them to preset it to 15lbs. It comes with a couple of shims so you can tweak it.
Old Oct 21, 2006 | 11:48 AM
NoSeeUm's Avatar
I am using this one. So far so good.
Jim
Old Oct 21, 2006 | 12:52 PM
piperca's Avatar
Jim,
Where do you have the Mallory mounted and what pressures are you seeing?
