Brand Spankin' New Huffer
Old Apr 12, 2003 | 11:38 AM
Don M's Avatar
DTR Advertiser
Re:Brand Spankin' New Huffer
Im waiting on a box from Kurt with this new divorced wastegate myself. We have been using the B1 with great results. After the 500HP mark fell on the baby ricer rocket dyno we are stuck with-it is now becoming important to get the gases outta the engine even more. <br>We cant seem to break the B-1. Yes, we try all the time. From generally acting like a kid on the backroads to running pull after pull on the dyno with large barks of pain coming from the turbo @ pedal lift.<br><br>The wastegate will just be an additional benefit. Now were is that box from New Mexico?<br><br>Don~<br><br><br><br><br>
Old Apr 12, 2003 | 12:37 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=StakeMan link=board=7;threadid=13476;start=0#127362 date=1050163876]<br>Great information Rod. At what RPM does that turbo begin to spool?<br>[/quote]<br><br>The gauge starts reading 2 PSI at about 11 - 1200 RPMs.<br><br>Rod
Old Apr 12, 2003 | 01:10 PM
KwikKurt's Avatar
[quote author=Push Rod link=board=7;threadid=13476;start=0#126970 date=1050077606]
[quote author=Spark Chaser link=board=7;threadid=13476;start=0#126892 date=1050068229]
May I ask how big the ex. housing is?
[/quote]
The turbine housings are a little different than what you guys are used to seeing. The B1 is available with a couple housing [sizes, AND a couple wheel sizes, so its a little tough to determine. It would be comparable to a 10cm Holset housing, I think (Kurt, correct me if I'm wrong here), but capable of moving more exhaust.
Rod
[/quote]
Wild Kitty, The housing will be more like a 12cm or 14cm depending on which turbine wheel we machine it for. KobraKwikerthen-everKurt
Old Apr 14, 2003 | 03:22 PM
Push Rod's Avatar
Well, at the risk of blowing KwikChilliGasKurt's already monumental ego right into the stratosphere, I'll throw some more numbers out:<br><br>First, I got the torque converter wrong. Its a 91% converter on the truck.<br><br>Now onto more meat:<br><br>1) Unlike a cowardly administrator in these parts, the cowl hole got drilled on the weekend. With the cowl hole open, EGTs will _not_ climb above 1300F for love nor money.<br><br>2) At a standing high idle (truck in park), the boost gauge will read 2 - 4 PSI at 2500 RPM. For comparison, a stock HY35 will read somewhere around 2 PSI at the same RPM.<br><br>Next phase is to mess with the wastegate a bit and see what we get...<br><br>Rod
Old Apr 14, 2003 | 05:04 PM
scottrod's Avatar
Rod-
Since this B-1 seems to running a smaller housing than most. What do you figure is the most boost you will be able to run without going out of it's efficiency map?
Just curious cause most guy's running 40's use bigger housings than what this B-1 has.
Old Apr 14, 2003 | 05:44 PM
StakeMan's Avatar
Rod,<br><br>I was able to hit 6psi+ in park with my HY35. Did the HY35 have many miles on it?
Old Apr 15, 2003 | 02:36 AM
Push Rod's Avatar
It appears as though the initial numbers that were delivered to me were in error. The dealer has been suitably whipped and we will be sending him a 'Learn your ABCs and 123s' as soon as possible.
Pics are a little fuzzy, but its 8-9 PSI of boost at 3500 RPM while in neutral...
Stake, on the 2500 RPM thing, you're injectored a little heavier than this truck, so you'll probably build a little more boost than this truck did.
Rod
Old Apr 15, 2003 | 02:45 AM
Push Rod's Avatar
[quote author=Spark Chaser link=board=7;threadid=13476;start=15#128002 date=1050357882]<br>What do you figure is the most boost you will be able to run without going out of it's efficiency map?<br>[/quote]<br><br>Sparky,<br><br>The turbine side shouldn't influence the efficiency range of the compressor side, and the B1B compressor is unchanged. Drive pressures can be influenced by a smaller housing, hence the wasting. We;ll be playing with the truck over the next couple weeks to determine what the right boost level is for his setup.<br><br>Rod
Old Apr 15, 2003 | 09:21 AM
hellotbone's Avatar
Hey Rod those are my gauges thats a spy photo LOL just kidding is that all you can get at redline! I didn't think you could do that with our trucks well off to the garage to revv it up! ;D
Old Apr 15, 2003 | 09:25 AM
StakeMan's Avatar
It did 6+psi with stock injectors and a EZ.
Maybe I had a good HY35. I know someone else who is enjoying it now.
It is part of a compound turbo setup now.
Old Apr 15, 2003 | 10:25 AM
BigBlue's Avatar
I can't get any boost in park no matter how high I rev it. ??? :'(
Old Apr 15, 2003 | 10:30 AM
hellotbone's Avatar
Poor Blue No Boost at Idle ??? thats odd my truck stock with the edge would make 4 PSI at idle is it dependent on the location of the line?
Old Apr 15, 2003 | 10:48 AM
StakeMan's Avatar
[quote author=Jamie Attridge link=board=7;threadid=13476;start=15#128238 date=1050420626]<br>Poor Blue No Boost at Idle ??? thats odd my truck stock with the edge would make 4 PSI at idle is it dependent on the location of the line?<br>[/quote]<br><br>If you are talking about where the boost gauge gets it readings from. Mine is in the port next to the map sensor. Which is suppose to read lower.
Old Apr 15, 2003 | 10:59 AM
BigBlue's Avatar
Stake that's where I have mine.
Old Apr 15, 2003 | 11:35 AM
Push Rod's Avatar
[quote author=Jamie Attridge link=board=7;threadid=13476;start=15#128238 date=1050420626]<br>thats odd my truck stock with the edge would make 4 PSI at idle is it dependent on the location of the line?<br>[/quote]<br><br>Jamie, was this with the stock turbo? Line run into the manifold? I'd suspect something was up with those readings, as I don't think I've ever seen a truck throw boost at idle, except a set of twins that were very efficient.<br><br>Rod
