Boost Pressure Leak Test
Old Jun 23, 2007 | 08:10 PM
Big Blue24's Avatar
I want to check my intake system for leaks. I was wondering if I need to plug the intake horn or if the engine is tight enough that it will hold pressure when I place a cap and valve stem on the compressor housing of my turbo. I'm most concerned with leaks in my stock intercooler but while i'm at it, i thought I might as well check the intake manifold as well. Any thoughts? Anyone else done this before and ran into problems?
Old Jun 23, 2007 | 09:42 PM
Homestead's Avatar
Don't worry about the motor itself, just pressurize it from the turbo inlet and go for it. If you have a leak, it will show up. The engine itself will leak down but it will hold pressure long enough to find a leak if you have one.
Put a little dish wash soap in a spray bottle of water and hose every connection down including as much of the intercooler as you can, your leak will show up.
Jeff
Old Jun 23, 2007 | 09:52 PM
WUnderwood's Avatar
what homestead said, he is dead on the money
zx14on2
Dec 19, 2011 06:52 PM
arroyojim
Oct 9, 2007 07:02 PM
F. Flack
Oct 24, 2005 10:11 PM
