Boost issue
Old Mar 15, 2007 | 09:22 AM
HOdiesel80's Avatar
Boost issue
Okay all, I have a problem with my boost pressure. I can't get it above 20 psi no matter what I do. I have a boost elbow and the EZ, which I thought was a boost fooler, but see no increase in boost pressure over stock. Is there something I'm not doing, or do you think it is some other issue?
Old Mar 15, 2007 | 03:42 PM
Sea:\>Drive's Avatar
The elbow increases the boost, the boost fooler just lies to your computer to stop it from throwing a code. Recheck the elbow and be sure it is adjusted tight (they are adjustable so you can control the boost).
Old Mar 15, 2007 | 04:00 PM
HOdiesel80's Avatar
Adjusted tight??? As in screwed in further, I assumed that screwed out would allow more boost through.
Old Mar 15, 2007 | 04:28 PM
HRDROKN's Avatar
Yes, screwed in blocking the signal to open the waste gate...
Should get you around 25 psi.
Old Mar 15, 2007 | 05:29 PM
graphitecumnz's Avatar
When I had an EZ, I was able to see boost levels of around 32psi.
If you have an adjustable boost elbow, you want the screw to obstruct the orifice... the elbow from Edge should already be constricted.
Old Mar 15, 2007 | 05:30 PM
Lil Dog's Avatar
OK, I think we are confused here. Opening up the allen screw on the boost elbow will open the wastegate per stock settings. Screwing the allen screw into the boost elbow will effectively begin to block the wastegate from opening until higher boost pressure is achieved.
Why did you adjust it? Mine out of the box works just fine..
Old Mar 15, 2007 | 06:01 PM
HOdiesel80's Avatar
I adjusted it because I had to order an elbow seperate because I got my EZ of ebay. Thanks for all the replies, after I'm done writing I'll screw it all the way in and see how she purrs in the morning.
Old Mar 15, 2007 | 08:32 PM
TNfarmboy's Avatar
Don't forget you could have leaky intercooler fittings affecting your boost.
Old Mar 15, 2007 | 10:17 PM
dodgediesel's Avatar
Or you could have a crack in your plastic boost line to your guage like I did. Boy, did I feel stupid!!!
dan123dbl
Feb 13, 2015 05:47 PM
rfinn04
Dec 18, 2006 05:33 PM
DodgeCowboy
Jul 1, 2006 11:13 AM
DDysput
May 5, 2004 07:44 AM
