Bolt on traction Bars
Old May 13, 2006 | 04:00 PM
mvanhelden's Avatar
Does anyone know if there is a complete bolt on traction bar kit available for my truck (see sig). I would buy a weld on kit but have no access to a welder.
Old May 13, 2006 | 08:03 PM
BigBlue's Avatar
I'm running the tuff country ladder bars and I'm pleased with them. Simple bolt on installation. Got them from rockymountinsusp.com for I think $350 shipped.
Old May 13, 2006 | 08:32 PM
mvanhelden's Avatar
Thanks for the reply. How do they attach to the rear axle, and do they limit the articulation any?
Old May 13, 2006 | 09:54 PM
BigBlue's Avatar
They attach to the bottom of the u-bolts with a plate. They haven't limited articulation on my rig cause I've had one side of my rear axle stuffed into the fender with the other just sorta hanging.
Old May 13, 2006 | 11:07 PM
mvanhelden's Avatar
Sorry for all of the questions, does the plate that comes with the kit go over the previos u-bolt plate or does it come with a new one, and did you have to drill the frame?
Old May 14, 2006 | 12:37 AM
Moose10's Avatar
Superlift makes these:
http://www.4wheelparts.com/4wp/produ...UP&expand=sub4
I know it's only listed for 68'-93' but if you check their site or call 'em they might be able to help you out.
Old May 14, 2006 | 01:06 AM
GlennRMK's Avatar
RCD also makes them. Look real nice!
But they are upwards of $600
RCD Traction Arms
Old May 14, 2006 | 05:21 AM
PourinDiesel's Avatar
Diesel Poole Darryl makes a set that are bolt on for truck pulling...810 853 1060 that are for your year of truck. A couple different friends of mine have them and truck pull with them.
They are single bar with heims at the end. There is a plate that bolts to the bottom of the axle u bolts. And a plate that bolts to the frame.
Old May 14, 2006 | 08:05 AM
BigBlue's Avatar
They go over your existing u-bolts and then you do have to drill the frame. 8 1/2" holes. That sucked.
O.T
26
May 3, 2008 09:37 AM
ckt_santiago
16
Apr 23, 2007 09:29 AM
Nuttymopar
Sep 16, 2004 12:48 PM
y-knot
Oct 29, 2003 11:39 AM
Captain
Dec 17, 2002 06:32 AM
