BHT3B Inducer wheels
Old Jan 17, 2007 | 12:06 AM
Muddin_dude06's Avatar
I am going to be installing my twins in the next month or so () and am wondering if I should go with a BHT3B with a 77mm Inducer wheel or stick with a 74mm wheel? I will have to pay an extra $250 to get the 77mm (will also include a polished compressor wheel cover) would it be worth it? I'm aiming for 600hp+ at the wheels on diesel only, would I NEED that extra 3mm's of inducer wheel? Thanks for helpin'!
Old Jan 17, 2007 | 08:18 AM
gunracer1's Avatar
the 74 will work, to get you in the 600 range.
Old Jan 17, 2007 | 05:15 PM
Mike Holmen's Avatar
The Guru
I would use the B2 turbo instead of the 3B turbo. 3B are abit sluggish and the B2 will move slightly more air than a 3B.
Old Jan 17, 2007 | 05:21 PM
Well I have thought of that as well BUT I already have an HT3B that I am using to mock-up the twinset, infact at the moment I'm warmin' up inside from being outside finishing the hotpipe . Plus I plan to make a few sets of piping for some people so having the extra turbo for mock-up will just make it a little easier I think. Do you not like your BHT3B in your setup?
Old Jan 17, 2007 | 09:42 PM
The Guru
No there nothing wrong just that I've heard that the B2 will spool faster than the 3B. I've also heard that its noiser than the 3B. I can pull around the 70psi range. My truck has the cam and head so the lag is so bad. A stock truck would more than likely different. I'm also at 3000ft, so its not helping my spool-up
cumminsdriver635
Sep 6, 2007 11:21 AM
kantdrive55
33
Jan 17, 2007 05:21 PM
satburn
20
Oct 2, 2006 12:21 AM
emfc_22
21
Sep 13, 2006 09:50 AM
More Power
Sep 17, 2004 04:09 PM
