BHAF--omigosh!
Old Apr 26, 2008 | 09:13 AM
danalex's Avatar
BHAF--omigosh!
Ordered my BHAF Thursday noon from www.fleetfilter.com. Amazingly it was on my doorstep Friday afterwork--fantastic service!
OH MY GOSH!! That is one GI-NORMUS HONKIN' FILTER! Connection was easiest thing I've ever done to the truck--besides insertinging the key into the ignition. The previous owner had used an oil-coated K&N, so I had expected to find the hose with a film of oil, but it was actually clean and dry. Checked the turbo blades and they too were clean. QUESTION: Does anyone have the constructin specs for building a "divider/spacer" between the BHAF and the turbo? I saw a link to a guy's website a few days ago, but it's no longer working. ...gotta update my signtr now...
Old Apr 26, 2008 | 09:19 AM
high bid's Avatar
go to the technical section, I think there is an actual size diagram you can print out and use as a template. Or maybe search for BHAF.
Old Apr 26, 2008 | 09:20 AM
roughstock's Avatar
Search "BHAF heat shield" There should be some thing out there. They are on EBay for $50? or so. Easy To make. There is a template on here some where.
Just print out, tape together, the trace on steel.
Old Apr 26, 2008 | 11:35 AM
daboocru's Avatar
bhaf
I am looking into doing the same thing to my truck. Using a BHAF from fleetfilter. Do you still have the part number of the one that you used and did it fit your stock tube?
Old Apr 26, 2008 | 12:05 PM
mikmaze's Avatar
part 42790 works for me, tiem I got a new one, I have 40k m i l e s on mine
Old Apr 26, 2008 | 12:06 PM
GFB's Avatar
GFB
You'll need a short piece of 4" pipe to use as a coupler between the filter and stock air tube.
Old Apr 26, 2008 | 12:11 PM
daboocru's Avatar
Thanks for all the info. Also i noticed all lot of people use the water repellent outerwear or prefilter. Worth it?
Old Apr 26, 2008 | 12:43 PM
mikmaze's Avatar
I have it on mine, keeps that paper protected a good bit better than without.
Old Apr 26, 2008 | 12:53 PM
HOHN's Avatar
I don't think the paper is at risk unless you occasionally take water over the hood.
Old Apr 26, 2008 | 05:14 PM
smokin95's Avatar
Got 17000 miles without prefilter and im on dusty gravel roads alot. Just wait till they go on sale at napa and then they are less than $35!!!!
Atleast they are in my neck of the woods...
Old Apr 29, 2008 | 11:42 AM
Mechanos's Avatar
I use the AH19004. No prefilter needed.
Old Apr 29, 2008 | 01:25 PM
Buckskin03's Avatar
Here is that link you were asking for. This has the template for the heat shield.
http://www.cumminsdatabase.com/read.php?id=15
Old Apr 29, 2008 | 03:09 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Here it is right on DTR https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Apr 30, 2008 | 07:32 PM
danalex's Avatar
...ended up making my own heat shield...cost me $3.00...see link: https://www.dieseltruckresource.com/...d.php?t=202597
Old Apr 30, 2008 | 08:16 PM
scottsjeeprolet's Avatar
You can also drill a hole in the end of the filter and put your filter minder in it. I did.
