best stack with XZT+
Old Jan 23, 2008 | 02:11 PM
skidooer76's Avatar
I was wondering what the best stack would be with the XZT+ any info would help.
Thanks in advance.
Old Jan 23, 2008 | 02:17 PM
haloman's Avatar
Any fuel only box, such as a TST
Old Jan 23, 2008 | 02:26 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I'm running a XZT+ and a Xzillaraider together. I really like it. My truck down-right RIPS. I haven't put it on a dyno yet, but I'm hopeing to do so this coming month.
Old Jan 23, 2008 | 02:42 PM
Krob's Avatar
Not to be dumb but isnt a xzillaraider a timing box to so isnt that bad and could cause damage? Educate me here.
Old Jan 23, 2008 | 02:50 PM
JPR Ram's Avatar
No the Xzillaraider isn't a timing box. It's a fuel box only. The only connections are; the VP-44 wire tap; the throttle position wire tap; MAP sensor plugs (into & out of); fused power and ground.
I also had a few questions, but Quad himself says they will NOT harm anything (besides what damage power can cause) and he said that they run great together.
I also thought, at one time, thought the Banks Ottimind was a timing/fuel box. Come to find out, it's a fuel only box. There has been a few sucessful stacks using the Banks Ottimind on top of the XZT+ from guys here on DTR.
Old Jan 23, 2008 | 02:53 PM
skidooer76's Avatar
I think when I bought my truck the guy had a superchips downloaded on it at one time, when he took it off would it leave the timming advance on there, I went and had my dealer do theecm reflash and now it seems that the motor is not near as loud as it was before and seems to be slower and I have also lost about 1.5 gal/mile?????????
Old Jan 23, 2008 | 03:00 PM
JPR Ram's Avatar
I believe the Superchips downloader does timing also. So it and the XZT+ wouldn't be a good stack. I would think you'd end up with too much timing and possible damage. Maybe I'm wrong.......
Old Jan 23, 2008 | 03:14 PM
J Lent's Avatar
The TST is a good choice, but I'd trade the XZT+ in & get the Adrenaline if you want more.
Old Jan 23, 2008 | 03:21 PM
mcoleman's Avatar
I'm going to be trying a friends XZT+ with my TST COMP model to see if I like that stack as well as the EZ/TST we are also planning on trying some of the different downloads to see if they make a difference.
Old Jan 23, 2008 | 08:54 PM
9 sec camaro's Avatar
I have it stacked with the banks kit runs good on all out runs but I have the miss with it just cruising I also have stage 3 jammers with the mix.
Old Jan 23, 2008 | 09:55 PM
JPR Ram's Avatar
Hey 9 sec camaro - I think I know how to solve your issue. The problem/issue I had with the Banks is that it is not adjustable or even able to be turned off. Put a on/switch on the wire going to the pump wire tap. If I remember correctly, it should be the yellow one???? Any ways, by putting the switch on, you can now either turn the Banks fueling capibilities off or on on-the-fly and it will not effect the gauges.
Old Jan 23, 2008 | 10:44 PM
qzilla's Avatar
I am starting to think the jammer series of nozzles are drippy.
I have several people testing a file right now that changes when the timing is advanced. I think in some cases we are too aggressive with how soon we start advancing the timing. This really shows up with the Mach 5 or 6 injectors or bigger.
It does seem the jammer guys have this same issue with smaller injectors. It makes me think that they might be drippy at low pressures. What I think is happening is that the additional fuel gets in too early with too little air and causes it to sort of put the fire out. I don't think its major but, I do think it could cause a stumble miss or shudder. I will let you know the results ASAP. If that is true we will have some reduced or changed timing options up on the website.
Old Jan 24, 2008 | 02:21 PM
skidooer76's Avatar
Quad - could I stack with another of your products,if so which one. would it be possible to get a file with more timming in it for my XZT, I am still having surging issues with the HRVP44 file downloaded,any ideas??????
Old Jan 24, 2008 | 02:30 PM
JPR Ram's Avatar
skidooer76 - see my post above. I have Quad's XZT+ stacked with Quad's Xzillaraider. Have you tried the Small Injector file? I like that one best for dailly commuting. But then agian, I only have RV275's.
Old Jan 24, 2008 | 02:44 PM
skidooer76's Avatar
Thanks JPR -I was just trying to get all the options I can so I make the best choice possible,I need to get my xzt ironed out first.
I send out a big thanks for any info to everyone
