Best stack option with Power Puck??
Old May 18, 2007 | 09:39 PM
kwhite's Avatar
I've got a puck installed. My sig tells the rest. What would be the best bang for the buck stack with the puck?? I guess the puck taps the pump wire because it plugs directly onto it. Which chip could I get to go into the ECM??
Thanks for the help!!
Old May 18, 2007 | 10:34 PM
qzilla's Avatar
The puck does everything on the data bus. Now you need to tap the wire.
Best bang for the buck would probably be our XZT box that taps the wire. You will need to call a vendor on here or the DTR store to get actual pricing but, they are pretty darn cost effective. They add 65hp via the pump tap and this is one of those rare cases where you can get close to adding 65hp + 50 and get 115 or more horsepower out of them.
Running them together will eventually trash the stock auto you have. And you are going to want gauges with both of them.
Just for reference, you know how the puck felt compared to a stock truck. This will feel that good again and probably actually a little better when you stack it. 65hp on the pump versus 50-65hp on the bus is night and day difference.
Old May 19, 2007 | 11:16 AM
kwhite's Avatar
Thanks qzilla.
I'm thinking that my tranny was upgraded sometime before I bought it. It has a TCI deep pan on it and it shifts really hard. I haven't gotten any numbers off of the tranny yet but I may try and look them up. The only gauge I have right now is fuel pressure. I need some more gauges I guess.
I have thought about the XZT module. So you you don't think I will have any problems other than the tranny?
tex23455
Feb 18, 2008 07:57 AM
BIGDAN65
16
Jan 23, 2008 10:02 PM
goose2w1
May 8, 2007 02:03 PM
rkelley
Apr 15, 2007 07:54 PM
emoryemt-i
Mar 10, 2007 01:01 AM
