Bent a pushtube.
Old Dec 11, 2005 | 10:05 AM
TurboDeezul's Avatar
Bent a pushtube.
Anybody know if there is an upgrade for the pushtube and rocker arms for the 24 valve?
Billet and chro-moly would be nice.
If not, I'll put some stockers back on. Thanks in advance.
Old Dec 11, 2005 | 11:12 AM
turbo thom's Avatar
If that's what you want, they will have to be custom built. Might not be a bad idea.
Preston
Old Dec 11, 2005 | 01:26 PM
AlpineRAM's Avatar
Why did you bend it? sticking valve or too high RPM?
Old Dec 11, 2005 | 03:01 PM
Scotty's Avatar
Top's Younger Twin
It can happen from extended idling too.
Old Dec 11, 2005 | 04:58 PM
AlpineRAM's Avatar
I'd say it's a sticking valve then...
Old Dec 11, 2005 | 04:59 PM
Don M's Avatar
DTR Advertiser
yep, from build up
Old Dec 13, 2005 | 04:41 PM
Yeah, sticky valve. A bit too much idling. I thought I bent a valve but after playing with it, it slowy came back up. I just need to clean it off, (the varnish)
What is a good oil varnish residue remover?
Old Dec 13, 2005 | 05:56 PM
HOHN's Avatar
There's a TSB on this. The solution outlined in the TSB was something along the lines of letting the engine rev to 3000 rpm in neutral for a couple minutes
The TSB refers to valve deposits from extended idling and THIS supposedly causes the bent pushtubes.
Let me see if I can find the TSB text....
FOUND IT:
STICKING VALVES - SERVICE PLAN
Short Term:
Reactive short term: Repair and clean cylinder head as required.
Proactive short term: To prevent or decrease the risk of this occurring to an engine which frequently idles for long periods of time in arctic temperatures, Cummins recommends the following:
Use of a winter front on these trucks
Use of a block heater when the engine is idling.
If the truck is already equipped with an exhaust brake, it should be turned on during idle.
Prior to shutting off the engine after extended idling (6 hrs) it is important to bring the engine to operating temperature (minimum of 140 degrees) to remove any carbon build up on the valves. This can be accomplished by driving the vehicle for 20-30 minutes or;
NON-Chrysler: Operate the engine at high idle for 5 minutes or until engine reaches 140°F.
Chrysler: Run the truck at 2000 rpm for two minutes, 3000 rpm for two minutes and then 3500 rpm for two minutes, until the engine reaches at least 140°F.
Old Dec 15, 2005 | 04:45 PM
Hey, thanks HOHN.
I,ll put it back together and run it down the freeway for a half hour.
Time to get that Pac Brake back out.
Old Dec 15, 2005 | 04:55 PM
Bobcat698's Avatar
Scheids has them.. Call 800-669-1934
Old Dec 15, 2005 | 05:09 PM
pmtg's Avatar
[/i]
probably pretty tough to get it to 3500 rpm with a 3200 rpm redline
Old Dec 15, 2005 | 06:40 PM
B.A.Ram's Avatar
just because it redlines at 3200 doesn't mean you can't go past that. Our tachs go to 4 if memory serves me right...
Old Dec 15, 2005 | 07:31 PM
BigBlue's Avatar
In neutral or park I can hit 3500. In drive I can only hit 3200.
Old Dec 15, 2005 | 07:35 PM
PourinDiesel's Avatar
Scheid Diesel or Haisley Machine has the billet push rods, billet tappets, and billet cams....
Old Dec 15, 2005 | 07:36 PM
Diesel-Dan's Avatar
well....its a ECM Limited 3200 RPM......unless you catch too low of a gear when down shifting.....i dont think you could ever see above that stock........
I know...ill put some 4K Springs in my VP-44!!!
