Bed liner
Old Aug 14, 2005 | 09:25 AM
wrangler's Avatar
Bed liner
Im goint to have a reflex liner sprayed in mt 01 Ram over the rails but am considering having it also put on the sides of the truck from the line on the door (about 3"up from bottom of door) tto the bottom front to back. The truck is black and the big tires just chip the paint and it doesnt look good. Thought this might solve my problem, If anyone has done this please let me know pics would be even better.
Thanks Wrangler
Old Aug 14, 2005 | 09:43 AM
TRCM's Avatar
Here is a shot of a friend of mines' truck. He had his done a bit higher than you want, but it should show you how it will look. I am gonna do the same thing to mine shortly.
Old Aug 14, 2005 | 10:28 AM
MedicShawn's Avatar
Here's mine with Line-X
Old Aug 16, 2005 | 10:40 AM
wrangler's Avatar
Thanks for the pix I think it looks great But does it hold up well and would you do it again. I think Im going to do it but its soo permanent.
Thanks Wrangler
Old Aug 19, 2005 | 06:02 AM
argve's Avatar
I had that done on a truck that I used to own (rhino) and peeled off but they put it on super thin and did not prep it correctly so they redid it for free and then it was on there like paint - correction it was on there better than paint. The shop that did mine had never hear of anyone having it applied to outside the bed before (I had mine done many years ago when the stuff was first out on the market) so they put it on to try and make it look like paint did not want the big bumps that are associated with Rhino on the outside they were trying to do me a favor. Me I wanted the rough and tumble look from the get go.
Stopped all the rock chips you can get it sprayed on with color mixed in and if they match the color correctly it looks like paint (just a orange peel paint job no less) but the added protection makes up for it many times over.
Old Aug 19, 2005 | 09:33 AM
CODODGE2500MAN's Avatar
I love the bed liner, Mine's a little higher though, but it Is well worth it. I have more pics in the gallery if you want to check them out. If you end up doing yours, go ahead and post the pics so we can see!
Old Aug 19, 2005 | 11:59 AM
Nuttymopar's Avatar
When I first got my 1st gen. It had some bed liner crap on the sides. Not really sure who it was by. I did like it as it did protect it rather well. But after a couple of years, rust started showing up under it so I tried taking it off so I could paint the door panels and stuff. Well let me tell you that it doesn't come off that easy. Even with the sandblaster, it would just eat up the blast and not really come off. Took some doing but it did finally come off so we could repaint. (tried painting over it and no good, just gets gooey).
But, I would recommend it as it did what it was suppose to do. Just a pain to fix things afterwards as it is thick and permanent.
Old Aug 20, 2005 | 12:33 PM
Ben's Avatar
Ben
[IMG] [/IMG]
Here's mine. Rhino lined.
Does it work to prevent rock chips. Yes
Would I do it again. Big Fat No, because of the rust factor behind it and I've already experienced.
I drive about 1/3 of the time on gravel roads. I'll deal anyday with rock chips over rust.
Old Aug 20, 2005 | 01:04 PM
TRCM's Avatar
Ben,
What do you mean rust under it ?? I was thinking of doing mine just like yours, bed & rockers. Not so sure now. Can you explain a bit more what the problems were ?
Old Aug 20, 2005 | 01:19 PM
Ben's Avatar
Ben
TRCM,
I smoked 2 deer on the passenger front last Oct. Needed new front fender. Well, they peeled the rhino off of the front fender and the passenger side door to blend the paint with the new fender.
There was a spot of cancer behind the rhino on the fender and 2 big rust spots on the passenger side door. Wasn't real happy. Truck was immaculate when it was applied. 26k on the odometer. Only had it on there for 1.5 years.
All it takes is one pin hole to let moisture in then you're screwed.
If you're not in the rust belt then I imagaine you would be "ok."
The bedliner came with the truck and that "seems" to be holding up fine.
I have pictures of it somewhere. I'll get them up of the fender when I find them.
darrylmueller
Mar 17, 2013 07:42 PM
CZSteve
Mar 8, 2011 08:11 PM
Clane
May 9, 2009 02:50 AM
04ctd
Feb 18, 2005 05:30 PM
