BD Box
Old Apr 7, 2004 | 07:24 AM
Brad Gray's Avatar
BD Box
Anybody know where I can get a BD Comp box? Question 2 is where can i get it worth the money.
Old Apr 7, 2004 | 07:45 AM
Floorman's Avatar
well Brad i learned from another memeber here that using the comp box was not as good as using the ez and stacking it with another box mainly for fueling. the comp doesn't do as much to the timing as the ez. anyway just my 2 cents . i bought my bd box from Jannetty racing in waterbury ct they are a sponser here they gave me 10 % off.
hope this helps
Old Apr 7, 2004 | 11:54 AM
farmer dave's Avatar
So are you saying that the ez would be better for milage?
Old Apr 7, 2004 | 04:41 PM
greenworks's Avatar
check out www.bd-power.com
I run one it the same box as the edge comp, I picked the BD box because the dealer is 2 blocks from my house. It is a great box but you have to tap the pump wire which WILL void warranty so it comes with a price.
Old Apr 8, 2004 | 06:22 AM
Brad Gray's Avatar
Warranty, Whats that? My trucks been out of warranty for about 3 months now. its an 02 and has 114,056 my other is an 02 that shows 113,948. Thanks for the info.
Old Apr 12, 2004 | 10:34 PM
Mike Holmen's Avatar
The Guru
I've run a comp box for about 2 yrs and I luv the thing. The drag box with give you more fuel at the top end but most trucks kinda die up the higher rpm's. I have stacked the super chip and comp box. Its not a good stack but as it stumbles abit but when it works hang on. As for killing your VP44 pump, just make sure you have fuel at the pump. The only thing that kills the pump is weak lift pumps and dirty filters. I run a Fass pump and man the its like night and day from a cummins transfer pump. The warranty thing dodge doesn't even have a clue. Use the injection pump plate forget cutting the wire. I smoked a VP44 pump by plugging up my pick-up screen with dirt. Ran the truck for 5 miles with no fuel pressure. Thank goodness for warranty.
04ctd
Oct 5, 2006 08:27 PM
BLUTIC
Dec 16, 2003 09:00 PM
vince1
Jun 6, 2003 12:22 AM
bdog
Nov 5, 2002 07:29 PM
