Basics of a P-pump
Basics of a P-pump
My truck is showing conditions of a vp that is on the verge of going out...and im trying to stay on top of things and do my homework before it does. I am not very knowledgable on the p-pump process, and im hoping someone can fill me in on exactly what a p-pump is and how it works. Scheid offers the conversion, i don't plan on doing it myself, i was just wondering if this would be the way to go. my truck only has 145,000 miles and i want it to last much longer. are there any other options? thanks.
i would say to get a fuel system but you already have fass, some guys add old motor oil or 2stroke oil to the fuel tank when they fill up for that little bit of extra lubrication (how much im not sure) if it goes out then as far as i know you have 2 options, vp44 or p-pump.
Basically, you are replacing an electronically controlled rotary pump with an all mechanical inline pump. The P7100, which was standard on 94-98 12v trucks, does not bolt up directly where the VP44 sat, so things like the timing cover, injection lines, lift pump, and so forth need to be replaced. There is also the need to dial in the new pump to run well in this application.
The conversion can be done but some have reported issues with getting everything properly dialed in... if you're going to have someone do the conversion, have the professionals do it.
If we're talking several thousand dollars to do the swap, might as well just buy a 12v engine and have the whole engine swapped in. Just go with some fuel system upgrades and get that hotrod vp44. Ain't it supposed to be real good?
Put a fuel pressure guage on you vp truck, and an aftermarket lift pump and run it, when the VP fails buy a good replacement and drive it. Alway use a fuel lube.
You can buy a lot of VPs for 4,000 to 8,000 dollars.
You shouldn't have anywhere close to 4000 in a p-pump swap. Haisley has a kit with everything you would need for 1550 bucks minus the pump.http://www.haisleymachine.com/PERFOR...20PRODUCTS.htm
I was going to - but ended up getting a bad pump which drained my wallet so I abandoned the idea and sold back the stuff. 12v timining case, pump gear, pump, lines, re-poped injectors, riser for intake manifold, mounting brackets and getting fuel to and from the new pump. I had planned on a haisley cam and 12v lift pump but a fass will work well. They rock some socks when done well but can be a pain to get perfect (like jetting a carb) and little things would be in the way - resale value depending on buyer, MIL, what to do with the vp harness, cruise cntrl, tach, and the 2-8K that it may cost. Weigh the options and see what it means to you. Good luck!
TNutcher
TNutcher
OK so i'am kinda leaning more towards just getting a new vp...everyone says to put a SO pump on instead of another HO like i have now. How would i go about acquiring one of these pumps?
