B-1 vs Piers' HX-40
Old Nov 11, 2002 | 07:15 AM
PourinDiesel's Avatar
Re:B-1 vs Piers' HX-40
B-1 users,<br>How much fabrication goes into installing the B-1?<br><br>--Justin
Old Nov 11, 2002 | 10:01 AM
fahlguy's Avatar
Justin,
I know where you can get a cutom HX-50, that is a direct bolt-up (same $$ as B1). If you are interested let me know. You may not like it though on your automatic.....it may be real slow. It would be interesting to try. I am really happy with it on my truck.
I know that you have to fab the downpipe and use an adapter plate to your exhaust manifold for the B1. Someone correct me if I am wrong, but I believe that is what I told when I was considering one.
Bill
Old Nov 11, 2002 | 01:47 PM
Bill,
Thanks for the info!
I am not really interested in using the B1 at the moment, but I have a great respect for it and the numbers it can provide as a single unit.
Bill, you ought to come out next year to some of our sled pulls
in the southern Indiana area!
--Justin
Old Nov 11, 2002 | 03:48 PM
KatDiesel's Avatar
It bolts to the stock exhaust without an adapter. Most people already have an ATS manifold tho.<br><br>The fabrication required is making the downpipe accept a 4.5&quot; outlet. There are a couple of different ways to go about this.
Old Nov 11, 2002 | 03:53 PM
Rob Thomas's Avatar
[quote author=fahlguy link=board=7;threadid=5814;start=15#65068 date=1037030489]<br>Justin,<br><br>. <br><br><br>I know that you have to fab the downpipe and use an adapter plate to your exhaust manifold for the B1. Someone correct me if I am wrong, but I believe that is what I told when I was considering one.<br><br><br>Bill<br>[/quote]<br><br>Bill and Justin,<br><br>There is no adapter plate on my B-1 (from exaust manifold) however I did have to weld the downpipe flange on, but no big deal, no other mods were made, and it was installed in a half hour.<br><br>Later, Rob
Old Nov 11, 2002 | 04:19 PM
Promoter's Avatar
Justin-You need to talk to Bill Robbins in Nashville. Do you know him?
Old Nov 11, 2002 | 08:55 PM
J.R. Adkins's Avatar
HEY SHHHHH! LOL He does some of my turbo work.<br><br><br><br>J.R.
Old Nov 12, 2002 | 12:02 AM
DarrellB's Avatar
[quote author=J.R. Adkins link=board=7;threadid=5814;start=15#65416 date=1037069726]<br>HEY SHHHHH! LOL He does some of my turbo work.<br>[/quote]<br><br>Busted! ;D<br><br>He's done a few pulling turbos on some tractors I know of. Also a couple PowerJokes too. <br><br>Darrell
Old Nov 12, 2002 | 07:40 PM
Rob Thomas's Avatar
To quote myself.........<br><br>[quote author=Rob Thomas link=board=7;threadid=5814;start=0#64958 date=1036997180]<br>Don,<br> <br> I was under the impression that the B-1 flows more air than an H2E, am I mistaken?<br><br>Later, Rob<br>[/quote]
Old Nov 12, 2002 | 10:16 PM
Don M's Avatar
DTR Advertiser
Hi Rob,<br><br>Unfortunantly there is no published compressor maps for the B-1 and many of the housings that guys are getting are the smaller, more restrictive and equilvalent to about 12CM squared HX35 housing to help get the mass of the heavy shaft and wheel combo that turbo uses to spool. This adds to restriction, but it does lower the moment of inertia (spool time) Trade offs like always.<br>The H2E on the other hand uses a 17CM squared housing which lowers restriction and the wheel/shaft combo is somewhat lighter to give about the same moment in spool up. Compressor maps show the CFM delivery of the H2E at around 750 at a pressure ratio of 2.7<br>Word on the street is the B-1 is supposed to be around 900 CFM, but we dont know at what pressure ratio this is or the wheels effeciency in the higher PR areas of the map.<br>I like the large housing B-1, but the lag can be somewhat painful. <br>Short answer is the B-1 may make more CFM but the H2E can potentially expel more CFM of exhaust gas. It goes back to trade offs.<br><br>Don~<br>
Old Nov 12, 2002 | 10:47 PM
Rob Thomas's Avatar
Thanks Don,
BTW I do have the big housing, yep there is lag, (compared to my HX-35) I learned to drive it different, don't even notice it anymore. Thanks again
Later, Rob
Old Nov 12, 2002 | 11:25 PM
Don M's Avatar
DTR Advertiser
Rob,<br><br>I think Larry C. has the big B-1 and it has worked very well with his engine. I did not speak with him about lag, but his high HP numbers are good with the turbo for sure.<br><br>We all know I dont mind a bit of lag. I prolly win that award.<br><br>Don~
Old Nov 13, 2002 | 12:26 AM
Rob Thomas's Avatar
Larry does have the big housing, I've been tryin' to catch him. I was hopin' he was going to Jesup GA for the pulls next week, but doesn't look like he'll make it. He has one tuff truck.<br><br>Later, Rob
Old Nov 13, 2002 | 06:55 AM
Sled Puller's Avatar
[quote author=Rob Thomas link=board=7;threadid=5814;start=15#66166 date=1037168772]<br>Larry does have the big housing, I've been tryin' to catch him. I was hopin' he was going to Jesup GA for the pulls next week, but doesn't look like he'll make it. He has one tuff truck.<br><br>Later, Rob<br>[/quote]<br><br>(good!)
Old Nov 13, 2002 | 07:14 AM
Gene are you going to Jesup?<br>Signing autographs?? <br><br>--Justin
