Autometer Guages?
Old Aug 11, 2004 | 08:52 AM
Mopar1973man's Avatar
Question Autometer Guages?
Ok... Here we go withe guage questions! (Yeah this is a old mute subject)
The pyro guage is not to much of a problem - install it PRE-TURBO and get a 0-1600F* guage with probe...
Boost Guage - Is a 0-35 PSI good enough for a stock turbo and stock engine? At the most I might chip it later.
Fuel Pressure? - Here is the heated one for me. I only finding 0-15 or 0-100 in autometer. Ok... There was someone else that used a boost guage for this purpose. Did you plumb stright to the guage or did you use a isolator? What other hardware do I need to install the fuel pressure guage using a boost guage from autometer? I'm also seeing people using needle valves?
It's time to hit the BIG BOYZ up for a little bit of knowledge!
Old Aug 11, 2004 | 10:09 AM
ratsun's Avatar
I used a Autometer 5404 mechanical 2 5/8 boost gauge as per the tech at Autometers recomendation( he thought I was mounting it in a cup on the cowl, NOT in the cab) Its worked great for a couple years now. The other parts were a needle valve in the top of the fuel filter canister and a 5' piece of 1/8" SS braided teflon hose conecting the two. Simple setup thats worked for me. No needle vibrations even with the needle valve wide open but a measure of security if there is a problem. If your running a stock fuel system the 15 PSI fuel gauge should work fine. Just make sure the gauge you get is a MECHANICAL LIQUID FILLED one or it wont last.
ratsun
Old Aug 12, 2004 | 08:27 AM
Anybody else have any ideas concerning guages...??
Old Aug 12, 2004 | 08:40 AM
Mcmopar's Avatar
Buy ISSPRO's
CTD06
Jul 2, 2007 09:42 PM
CalypsoCowboy
Jun 18, 2007 07:54 PM
A-Poc
Feb 7, 2006 02:56 PM
berner
Dec 25, 2002 04:28 PM
phox_mulder
Nov 9, 2002 08:17 PM
