arp head studs
Old Nov 14, 2010 | 06:28 PM
dieselboy59's Avatar
arp head studs
Hi I was on the arp web site.which 12mm head studs too use. there is two to chose from.one you tighten too 125 the other 150.which ones are most guys running.any info would be great.
thanks
Old Nov 14, 2010 | 08:03 PM
Tate's Avatar
The ARP2000's are the standard grade ones, run around $425 or so. The ARP 625's are the $1000+ studs that you torque to 150. No need to use those unless you are making a monster engine.
Old Nov 15, 2010 | 09:30 AM
HOHN's Avatar
True..
And the higher torque of the big-dog studs will increase (slightly) bore distortion caused by the fastener torque.
I'd recommend the big dog ones if a complete rebuild (new bore/hone/pistons/rings), or the milder ones if you're upgrading in-frame.
JMO
pwrtripls1
Mar 10, 2011 12:12 PM
Don M
32
May 12, 2006 02:37 PM
James Lucas
Jun 13, 2005 08:46 PM
BARTMAN
Mar 24, 2005 04:59 PM
jermey1980
27
Feb 27, 2005 06:11 PM
