Anybody done an aux tank in the spare tire well?
Old Aug 21, 2008 | 07:28 AM
sheriffav8r's Avatar
Since my spare no longer fits in the under bed area, I'm thinking of putting an aux fuel tank there. I'm thinking something along the lines of 2 16 gallon or 1 22 gallon racing cells. Connect them with dual lines top and bottom to the main tank. The tanks would be about the same depth as the main tank (maybe a little higher at the top) and hopefully wouldn't need any type of valving other than the rollover valves already installed. Anyone have any simple ideas? I'm not looking for anything in my bed so under it is about it....
Old Aug 21, 2008 | 04:27 PM
scottsjeeprolet's Avatar
Sounds like a good idea. My company's F350 service truck has the tank where the spare should be. Might scan the junk yards for one of those trucks for the tank then measure it to see if it would fit.
Old Aug 21, 2008 | 08:26 PM
carl48's Avatar
i have a transflow in a 98 12v gives 35 gallons extra had it since 99 no problems
Old Aug 27, 2008 | 08:07 AM
Yeah, I'm looking for something in my meager budget of around $200. I just want to figure out the plumbing before I do anything rash.... It seems that if I have the bottom of the aux above the bottom of the main and the top of the aux below the top of the main I should be okay with a sump drain at the bottom and a vent at the top connecting the two tanks....
Old Aug 27, 2008 | 10:52 AM
Dhorn33's Avatar
My 97 xcab long box truck has a tank in the rear of the truck where the spare was. It is a 25 gallon tank that holds my WVO.
Old Aug 27, 2008 | 10:13 PM
kawi600's Avatar
Im really interested in this too. Im looking for an aux tank for WVO.
frybrid makes a dodge-specific spare tire tank but its not cheap. Also there are plenty welders out there that will TIG weld you a tank together from aluminum sheet, but theyre not going to be cheap either. Its a lot of work to make a liquid-tight aluminum tank.
I could make one from steel, but it doesnt do well with WVO =(
Old Aug 28, 2008 | 10:37 AM
Dhorn33's Avatar
I am pretty sure my tank is stainless and it was likely custom made? It was in the truck when I bought it.
Old Aug 28, 2008 | 11:05 AM
2500's Avatar
pic's please... this is exactly what I need... getting ready to go with an in bed tank... if I can do this..
Old Aug 28, 2008 | 11:10 AM
2500's Avatar
transflow has em for $1189... good grief!
http://www.transferflow.com/Dodge_mi...uel_tanks.html
Old Aug 28, 2008 | 08:08 PM
I can fit a 32" long x 18" wide x 14" tall tank easily in the spare area where it would mount up to the cross-rail area near the tire winch (to be removed). I'm looking at this 22 gallon long tank (#11105) for $115:
http://wescoperformance.stores.yahoo.net/ecfuelcel.html
This would give me an extra 400 miles and the ability to travel over 1,000 miles on a fillup. I would plumb AN-6 or AN-8 lines from the bottom to feed it to my main tank. You wouldn't have to do this with WVO if you had a pump. I plan on mounting the tank with straps or rods supportinga a metal plate that the tank would sit on. It would be held tight and secured with the straps. Any thoughts????
ramsport59
MDDTR #33
Feb 21, 2008 04:15 PM
groran
Mar 19, 2007 07:44 PM
2500CTD
Feb 27, 2005 01:29 AM
EricBu12
Jul 17, 2003 09:33 PM
