Airdog Won't Prime
Old Jan 6, 2011 | 04:11 PM
jentas's Avatar
Airdog Won't Prime
I moved my Airdog out of the way to get to my transfer case for a fluid change, then after I put it back and started the truck, the truck cut out after a minute. Now, the Airdog won't pull any fuel. I tried filling the water separator with fuel to prime (like the installation instructions say), and it will just push that fuel through but won't pull any more from the tank.
I already pulled the cover off and checked the gerorator and it's spinning fine. I hooked the little shop vac to the fuel pickup line and was able to pull fuel from tank pickup, so it's not clogged.
It seems like there is way too much of a vacuum (major whoosh sound) when I crack the gas cap after trying to prime. Maybe the vent cap is plugged?
Any ideas?
Old Jan 7, 2011 | 02:06 PM
jentas's Avatar
Ok. Tank vent was not working, and the airdog was working against a vacuum in the tank. Had to gut the tank vent...maybe I'll get a new one, maybe not. Check your tank vent!
Old Jan 11, 2011 | 08:43 AM
Beretta40's Avatar
I had the same issue with my raptor not priming after removing the inlet screen, I removed the cap and took an air hose to pressurize the tank slightly, worked like a charm.
92smokin blacky
Mar 12, 2011 12:54 PM
wcialrlter
14
Jul 27, 2010 11:22 PM
MAC702
Feb 22, 2010 08:56 PM
hipsi
Jan 24, 2008 12:53 PM
neal dehmler
Dec 25, 2005 06:48 PM
