AFC spring kit
Old Feb 8, 2005 | 12:51 PM
Randy Hardesty's Avatar
Question AFC spring kit
I see these kits for sale and was wondering what effect do they have on the truck.Is it too help low end power of what? I was also wondering about arm adjustment on the plate.Mine is set right above the bottom nose on my #10, If You lower it down level with the nose does this give more fuel or less fuel?
Thanks,Randy
Old Feb 8, 2005 | 01:47 PM
Lil Dog's Avatar
The 215 hp pumps definitely benefit from the AFC spring kit.. The softer AFC spring allows for more full travel of the AFC cam and finite adjustment of the starwheel. With the stock spring the clicks on the starwheel are alot of adjustment with respect to the boost vs. fuel.
I found it was a nice compliment to the #10 plate. However I did not adjust the lever arm as I didn' t want to adjust the torque rise, 1500 RPM is good enough. By lowering the lever arm to the bottom you have moved your peak torque up so that you reach full travel on the plate later in the RPM range, probably 1800 or so.
For the $50 for the kit, it made adjustment easier and the fuel comes on nice and strong, not jerky.
J-eh
Old Feb 10, 2005 | 08:49 AM
Buckin Goat's Avatar
Does this give you anymore moke then you already had?
shrmpboatcptn
Mar 7, 2008 12:34 AM
Hercules
Nov 13, 2007 02:40 PM
Cummins Freak
Feb 10, 2007 06:05 AM
halerazor
14
Jan 18, 2005 05:28 PM
boehunter49
Dec 13, 2002 07:10 PM
