Adding electrical accessories
Old Nov 26, 2002 | 08:51 PM
rattle_rattle's Avatar
I hate wires in the cab. I want to run some permanent wiring to my radar detector, my GPS receiver, and a CB. More could be added later. I see Geno's has some "Painless Wiring Fuse Blocks". They are kind of pricey. Does anyone know of a source for fuse blocks by themselves? I already have relays and wiring.
Old Nov 26, 2002 | 09:22 PM
pilotmdurst's Avatar
Re:Adding electrical accessories
performance auto.<br>put one in my truck ...has spots for 6 items and holds blade type fuses <br>if i remember it was about 6-7 dollars<br>if you do not have one where you live i will mail you one if you want
Old Nov 26, 2002 | 09:24 PM
i will try to take a pic of it at work in the morning and post it on thursday for you<br>
Old Nov 27, 2002 | 03:21 AM
Bart Timothy's Avatar
I have the wearther proof Painless Wiring kit and it is expensive for what you get. If I was to do it over again, I'd build my own, using parts readily avialable form NAPA.<br><br>The slickest way to install a radar detector is to wire it to the rear view mirror.
Old Nov 27, 2002 | 07:00 AM
jfpointer's Avatar
[quote author=Bart Timothy link=board=7;threadid=7601;start=0#72940 date=1038388864]<br><br>The slickest way to install a radar detector is to wire it to the rear view mirror.<br>[/quote]<br><br>That would be pretty slick. I'm also thinking this is an interesting glimpse at the changes in trucks over the years--who would have thought 10 or even 5 years ago that trucks would have rear view mirrors with power running to them?
Old Nov 27, 2002 | 07:23 AM
NWDave's Avatar
[quote author=pilotmdurst link=board=7;threadid=7601;start=0#72889 date=1038367448]<br>i will try to take a pic of it at work in the morning and post it on thursday for you<br><br>[/quote]<br><br>You're going to post it here, right? I'm sure I'm not the only one interested in such an item.<br><br>~Dave
Old Nov 27, 2002 | 08:16 AM
Ryan's Avatar
For my radar detector I tied into a power lead in the over head concole and have a sort wire running from it to the detector. I picked up a 2 - 6 position fuse blocks at Autozone for about 4 bucks each. They use the standard ATO fuses. I had them mounted on the lid to the underhood fuse box on my Dakota and 1500 for interior accessories. Now that I have a few more lights they are al mounted on a board along with all of the relays and mounted on the pass side battery bracket.
Old Nov 27, 2002 | 07:53 PM
I found just what I needed at Advance Auto Parts. It's made by Buss and has six circuits ATC fused at 30 amps (max) for each circuit. Thanks for the help.<br>
96dodge2500
Jun 7, 2012 02:53 PM
J_T
Jan 24, 2007 06:53 AM
NHdodgeman
Nov 28, 2006 05:32 PM
jeffgian
Nov 10, 2003 09:48 AM
patrick
Mar 12, 2003 01:19 PM
