98.5 pusher pump problems
Old Jan 15, 2006 | 10:50 PM
STACKED's Avatar
on my 98.5 i've noticed that sometimes the lift, and the pusher pump wont run at all. i was wondering if this was due to the wiring that i've done. i am running the pusher off my lift pump wires.
Old Jan 16, 2006 | 05:40 PM
george7941's Avatar
If you did not use a relay to power the pusher then it is possible that the combined current of the LP and the pusher is overloading the ECM and its overload protection is kicking in and shutting off the current. On my Freightliner the ECM supplies the power for the LP, perhaps your setup is the same.
Old Jan 16, 2006 | 06:14 PM
BigBlue's Avatar
Same thing. You need to install a relay to run your pusher pump.
Old Jan 17, 2006 | 05:00 PM
STACKED's Avatar
thanks how would i run that relay.
NVRENOF
Oct 24, 2007 10:08 PM
cyawallac
Feb 28, 2007 04:03 PM
Big Smoky
Mar 23, 2006 12:11 PM
wrk24wheel
May 1, 2005 07:18 PM
midwestdually
15
Dec 17, 2004 08:52 PM
