60# valve springs
Old Oct 30, 2003 | 11:37 AM
DeereDiesel's Avatar
60# valve springs
Any suggestions on the best way to install the heavy valve springs without takin the head off? I was thinkin that if you put compressed air in at the injector hole that would work. It wouldn't blow the head gasket would it? runnin each cylinder around to top dead center to stop the valves from droppin would be kinda scary i'd think.
Old Oct 30, 2003 | 12:38 PM
y-knot's Avatar
Re:60# valve springs
Take it to someone and have it done.
Old Oct 30, 2003 | 12:42 PM
Rammin On's Avatar
Bring the cylinders to TDC and you can drop the valves on the piston tops ... do 1 & 6 - 2 & 5 - 3 & 4 at the same time ...
Old Oct 31, 2003 | 07:17 AM
bulthisl's Avatar
You DO NOT have to remove the head !!!!!!
I have changed MAny of them.
You just need the right tools and some time.
The back 2 are a pain in thr rear to get to and adjust.
Make you torque the head bolts Correctly or you will have probs.
If you can't do this give me a shout.
: Eddie : 8)
Old Oct 31, 2003 | 01:39 PM
Thanks for the advice. Iprobably won't get to it until later this weekend so if I have problems i'll pm ya.
Jordan5687
Jan 29, 2015 10:32 AM
53 willys
23
May 19, 2008 06:14 PM
12valve
Mar 11, 2008 10:57 AM
95turbo4wd
Dec 12, 2007 05:59 PM
bigred496
Oct 22, 2004 07:16 PM
