4.5" Skyjacker lift
Old Sep 29, 2003 | 01:29 PM
dukeboys's Avatar
4.5" Skyjacker lift
I have a 96 and recently bought this lift (class 1,standard) on ebay. My question to those who are running this lift or something close follows: Are you running 35,36,or 37's? Im looking for a rpm range with 4.10's,36"tires at about 60-65 in DRIVE. Anyone with pics?? :P
Jason
Old Sep 29, 2003 | 02:25 PM
James Lucas's Avatar
Re:4.5" Skyjacker lift
There are a few pics of that lift, I don't know if it's the same class, on a 2001 on this link...
https://www.dieseltruckresource.com/....php?album=335
I run 36" tires and they will rub in extreme turning...
My lift and Phox's lift both gained us 5 inches in the front and I ended up having to lift the back another inch.
James
Old Sep 29, 2003 | 02:34 PM
dukeboys's Avatar
Thanks for the pics James. Any other info on the RPM's your running ??? BTW sweet truck!!!
Old Sep 29, 2003 | 03:29 PM
Thanks for the compliment
My truck is running 355's so my gearing is WAY high.
70mph in OD is only 1550 rpm. I don't even use OD untill I am going over 70 (well over)
I didn't even comment on the rpm thing because you mentioned you have 4:10's.
I do use a TRUSPEED Sensor so that should be accurate.
James
Old Sep 29, 2003 | 04:48 PM
phox_mulder's Avatar
[quote author=JCL123 link=board=7;threadid=20308;start=0#msg190646 date=1064867374]
James
[/quote]
Yea, what he said concerning RPM's and Truespeed.
I'm seriously thinking about getting longer control arms, bout an inch longer if available,
then I can run 37's or 38's no problem.
Since replacing my front bumper, the tires look too far back in the fenders, and I noticed with my 315's (34.75 inches) I rubbed going into a steep driveway a little fast.
(wheels almost at full lock, hit the inside rear of the fender, just barely)
You'll have to replace the speedometer gear to make your speedometer correct, as you don't have the computerized one.
Here's the link to my album.
https://www.dieseltruckresource.com/....php?album=149
Has pics of stock, 2inch spacer, and 4.5 skyjacker.
phox
Old Sep 30, 2003 | 12:44 AM
dukeboys's Avatar
Sweet Phox!!!!!!!!!! ;D
Thanks for the info.
Jason
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Nuttymopar
Aug 25, 2004 07:05 AM
MPagnucco
Oct 17, 2002 09:50 PM
