3K GSK adjustment?
Old Jul 28, 2007 | 05:51 PM
CmminsBeast's Avatar
3K GSK adjustment?
I have a 3k gsk, I was wondering how do you know it's set right? I have had it for a while, but till friday I have not been able to really lay into the throttle. (Have new tranny) It shifts around 28-2900 and I have noticed the idle has been dropping. Is it alright to presume the gsk has backed off some since i had it put in(may have never been set right). Now I have a new tranny, i'm going to move my plate forward, and thought I might need to adjust the springs in the gov. So, which direction does turning the springs do what? Need some advice.
Old Jul 28, 2007 | 06:18 PM
clutch1's Avatar
if the idle is high you're to tight if you dont get the full effect of the rpm increase then you're to loose if set right then the idle will be the same as stock you shouldnt have to adjust it.
Old Jul 29, 2007 | 09:58 PM
Thanks for the advice.
Old Jul 30, 2007 | 10:53 AM
halfpint23's Avatar
Originally Posted by clutch1
<SNIP>if set right then the idle will be the same as stock you shouldn't have to adjust it.
........whew..... must have got it right. I was kinda sweating that one - I haven't got to drive it since the work was done.
Hubby hooked it to the trailer and I haven't got my hands on it since!
Old Aug 7, 2007 | 08:40 PM
Well I st it, it idles a tad high, but it's shifting around 28-2900rpm.
siebertl
Jun 10, 2007 02:29 PM
SHARPMACHINE
Mar 6, 2007 08:45 AM
plow
Aug 9, 2005 04:25 PM
MR HYDROSEED
Mar 9, 2005 10:49 PM
Got Smoke?
Oct 26, 2004 03:57 PM
