370's and dv's
Old Feb 16, 2006 | 07:32 PM
JKM's Avatar
JKM
370's and dv's
Can they be run with a stock turbo until i can afford a bigger turbo?
Old Feb 16, 2006 | 07:47 PM
Willy91's Avatar
You can probaly run them, but they would get real hot real quick at WOT and the truck would be one heck of smoke machine.
Old Feb 16, 2006 | 08:49 PM
TxDiesel007's Avatar
What he said is right on
Youd have a wicked low end as well. U would seriously need to get ur starwheel and ur plate in check as well tho.
Tx
Old Feb 16, 2006 | 09:43 PM
northslope's Avatar
I made lots of smoke on the mid to top end till I put on the HTT stage IIII compressor, now I have smoke on moderate take off tehn it clears right up, but it can be done with a stock HX. Don't know if I'd try any REAL towing or heavy loads without some sort of hybrid mod or different turbo though
Old Feb 16, 2006 | 10:41 PM
v8440's Avatar
I run 370's with stock 181 dv's and a #0 plate all the way forward. This is with the stock turbo, running about 31 pounds of boost. I just started smoking my clutch last night after I installed the plate. It took the previous #8 alright. I can tell you this-you can do it, but don't plan on making even a full 1/4 mile pass at full throttle, unloaded. With the #8, I was able to peg the egt gauge at 1500 for a second or two messing around at about 100 mph on the interstate, unloaded. I suspect that was partly due to having 4.10's and revving the motor up pretty good. But still, be careful.
Old Feb 16, 2006 | 11:00 PM
northslope's Avatar
Not trying to hijack but that zero plate is gittin 'r' done huh?
Old Feb 17, 2006 | 03:11 AM
halerazor's Avatar
i currently have a stock turbo with a 18cm exhaust housing 0 plate, 370's and laser dv's. daily driving it is fine but does have during moderate acceleration and smokes at take off, at full throttle it will shut down a 4 lane highway. egts are at 650* cruising empty at full throttle i'm not sure my gauge only goes to 1600* and it gets there in about 3 seconds. as far as a smoke machine heres a pic of my truck on the dyno
Old Feb 17, 2006 | 03:40 AM
Cummins Freak's Avatar
halerazor so you're saying that with those mods you can dd just fine? and how does that 18cm lag for dd'ing
Old Feb 17, 2006 | 03:47 AM
halerazor's Avatar
it is a little laggy but too bad it lights around 1800rpm wish i would have went with a 16cm but i only paid $35 for it and it keeps it cool at higher rpms. i was worried about my turbo exploding on that dyno run it can hit 55psi with no problem, but i keep my foot out of it and try not to go over 35psi. daily driving is no problem i can control the smoke and temps with my foot, the clutch is a pain in the butt though it's very grabby
Old Feb 17, 2006 | 09:16 AM
How do u suppose it would take a 14cm exhaust housing?
Tx
Old Feb 17, 2006 | 10:48 AM
JKM's Avatar
JKM
I was thinking on sliding the plate back , and maybe "un" cranking the star wheel , for now.
Would an HX40 help things out some?
Old Feb 17, 2006 | 12:06 PM
Willy91's Avatar
The Hx 40 would probably help for right now. I've got a buddy with the same setup except he has a full B-1 and his truck can still get a little on the warm side if he really pushes it
halerazor's Avatar
a hx40 would cool things down but for a few hundred more dollars you could get a fat phat shaft or a htt turbo
Old Feb 17, 2006 | 12:54 PM
where are you guys getting these fat phat shaft turbos
Old Feb 17, 2006 | 01:02 PM
halerazor's Avatar
phat shafts are sold by www.industrialinjection.com
high tech turbo also has some good turbos www.htturbo.com
