35# boost bad
Old Dec 2, 2005 | 03:59 PM
Cummins Freak's Avatar
35# boost bad
ok i just added my gauges and advanced my timing to 15.5* and ground a #100 plate....actually josh peters did most of the work thanks again josh.....ok my question is now with the gauges i see that my turbo can hit 35# boost is that bad for my head gasket and my stock turbo i also have the waist gate clamped off so if it is bad i can always re open that.
Old Dec 2, 2005 | 04:10 PM
smokindog's Avatar
Hey early 2nd Gen guys, what turbo is on texas's truck?
If it's an HX35, but I doubt it is, 35psi is the limit. Your head gasket will be just fine with that. What you are looking for is the maximum efficiency of the turbo. With the HX35 the max is between 34psi-36psi, any more than that and you are over speeding the turbo and also creating hot air instead of cool air (relative term, IAT is generally around 130*F).
Find out what turbo you have, the max efficient boost for that model, and set the wastegate there and you will be all set.
Old Dec 2, 2005 | 04:11 PM
G1625S's Avatar
35psi is the outer limit of the HX35 map. If that's what you're getting at max load, I'd say you're alright. Anything higher is overspeeding the turbo. If (when) you add more fuel, you'll need to re-enable that wastegate.
greg
Old Dec 2, 2005 | 04:13 PM
G1625S's Avatar
1994 trucks have WH1C's. 95-98 12 valves all had HX35's.
Old Dec 2, 2005 | 04:16 PM
hemijustin's Avatar
Nothing wrong with 35 psi.... thats about perfect for hx 35. and i wouldn’t worry about boost. im running 45psi on my stock head gasket.... what kind of egts are u seeing?
Justin
Old Dec 2, 2005 | 04:50 PM
Justin
highest i have gotten it is only 1050-1100*
Old Dec 2, 2005 | 05:01 PM
hemijustin's Avatar
hell your set up Golden....u can run at those temps all DAY!!!my truck runs 1250. and like 1500 on a really hard pull at least thats all my gauge tops out at..
Justin
Old Dec 2, 2005 | 10:11 PM
TxDiesel007's Avatar
32-35
Anything above 35 PSI on ur stocker is just hot air, that aint helpin u much, but yes you can get higher boost...
Tx
Old Dec 2, 2005 | 10:26 PM
Originally Posted by TxDiesel007
32-35
Tx
i know that going over 35-36# on stock turob is just hot air and i knew i did not want any more then 35# what i really wanted to know is if not leting my WG function and letting it hit 35# if i was going to hurt anything mainly my head gasket
Old Dec 2, 2005 | 10:58 PM
Fueling around's Avatar
It is really hard to give a definite answer to that question.
It will probably go a long time without any problems.
I'm running a little more advance timing and could hit 40 psi boost. I exceeded the head gasket smoking out a jerk that cut me off.
Old Dec 3, 2005 | 12:46 AM
12valve's Avatar
we broke 2 HX35 turbos on one truck in a very short time... i doubt we went over 35 psi...
a friend of mine made 38 psi w the stock hx35 on a 96 dodge manual. Bot only 4 a few days...and he blew that 1. now running a HT3B really cool!
Old Dec 3, 2005 | 01:30 AM
grow_ctd's Avatar
should be HX35
[QUOTE=smokindog]Hey early 2nd Gen guys, what turbo is on texas's truck?
If it's an HX35, Should Be a HX 35 if it is stock 97' Turbo.
Old Dec 3, 2005 | 03:44 AM
halerazor's Avatar
i can hit around 55psi on my stock turbo, but i try to keep it at a max of 35psi. just lucky i haven't blown it yet or a head gasket. 35psi should be fine
Old Dec 4, 2005 | 06:12 PM
WideOpenThrottl's Avatar
Old Dec 4, 2005 | 06:15 PM
blackdiesel's Avatar
Registered
i can pull my stocker up to at least 45 . maybe even 48. cant tell really, it jsut pegs my 35 psi guage
