3.54 and 35s?
3.54 and 35s?
I have 35s and 410s right now. I am seriously considering switching to 3.54. Is this combination tolerable. I dont tow very much. I have an EZ but thats about it. I plan on getting a comp box at some point. I already have gauges. How will it fair with the EZ. I hear it makes your EGTs go up and your boost go down. True?
I enjoyed my 35's when I had them. I thought it was a great combo with my truck. Highway mileage went up, city went down.
I'm going back to 35's because I'm mostly highway driving now. Around town tends to drag you down a bit but I never did mind it. I towed like I always did with the 35's, never an issue unless you go real heavy and in my case I put my 265's back on.
Jeff
Jeff
I do a lot of driving on the highway and I dont care as much about the milage as I do just going so dang slow. I cruise at 2200 RPMs or so and on the GPS on my phone its right between 72 and 73 MPH. Kinda tired of that. I dont like to run any more revs than that. I have an 01 5 speed and I think I have the tow package. Does this mean i have a dana 80 in the back and 60 in the front?
For 94-02 all cummins manuals had an 80 rear axle. All cummins 4x4 had a 60 front axle. If you had an auto cummins then you got the 70 in the rear. Unless you had a 3500 in which case you always had an 80...even with the gas motors.
New ring and pinion front and rear $200 (from the classifieds here on DTR)
New carrier for rear $335 (ebay)
New Front Bearings about $130 (ebay)
New Rear Bearings about $200 (ebay)
Lube and misc. about $50
Labor at a local shop $550
Mileage went up. I couldn't get better than 18 before and now I can get 21. Plus you can sell your old gears and carrier and recoup some of that money.
your 5 speed is what gives you the dana 80 in the back and 60 in the front. I'm not sure though on a manual what the towing package consists of.
5 speeds got a D80 also!
Captian Coop - with a 5 speed you can control rpm to deal with 35's around town. On hwy, with my auto, I get about 1800 rpm at 70 mph.... 2000 rpm at 80 mph, which is sweet. You will get slightly higher rpm due to 5th gear ratio.
As mentioned, if not towing over say 15,000 lbs, go for it.
I was quoted around $1,500 also..... half labor....half parts (new bearing in the rear, only). That was in L.A.
Labor probably cheaper in more rural area! Where are you?
RJ
RJ
As was said, if it's got a clutch, it's got a d80. RowJ is correct---staying under about 15k behind you and you will not regret 3.54's and 35's. Although not a perfect comparison since I'm p-pumped, I see about 17 in town and 20+ on the highway. Usually run 70-ish which is well under 2k rpms
