235hp or 245hp ?
Old Jul 16, 2009 | 08:10 AM
az4wheel's Avatar
235hp or 245hp ?
i have a 2000 dodge that i need a new injection pump i found a couple for sell used one is a 235hp, and the other is a 245hp witch one do i need or does it not matter?
Old Jul 16, 2009 | 08:14 AM
high bid's Avatar
My uncle works for a very reputable Bosch pump builder/supplier/dealer and recommended the 245 as that is the standard replacement....which I will be installing in the next week or two. If I were you, I'd buy new.
Old Jul 16, 2009 | 08:26 AM
az4wheel's Avatar
thanks i would love to buy new but i just cant afford it i have been trying for 6 months. work in new construction and it is slow.
Old Jul 16, 2009 | 08:53 AM
johnyb59's Avatar
is your truck a 6 speed?
Old Jul 16, 2009 | 08:55 AM
az4wheel's Avatar
4 speed auto.
Old Jul 16, 2009 | 09:33 AM
j-fox's Avatar
Your motor then is a 215 hp.
The 235 hp injection pump is for 2001 and 2002 auto. The 245 hp is for a ho motor.
Old Jul 16, 2009 | 10:00 AM
Mike D's Avatar
SO truck use the the 027 (235hp) pump and HO trucks use the 028 (245hp) pump.
The SO pump will put out more fuel if you're going for horsepower. The HO pump will probably give an SO truck better fuel mileage but lower overall horsepower.
Old Jul 16, 2009 | 11:41 AM
SIXSLUG's Avatar
Your HP is listed on the engine ID plate at the front, top, drivers side. It has your serial #, build code and other good info. Your hp rating is on it also.
Kurt
Old Jul 16, 2009 | 01:47 PM
Dinner's Avatar
I don't see why the HO Pump would be a standard replacement pump. His truck is an SO, so put an SO on it. Sure he might notice a little more oomph down low with a HO Pump. But once you start adding go fast goodies, the SO Pump out fuels the HO Pump.
Old Jul 16, 2009 | 04:37 PM
johnyb59's Avatar
^^^^software issues you can go from an HO to a SO without having the ecm flashed but not vice versa.
Old Jul 17, 2009 | 01:45 AM
Dinner's Avatar
Ah, forgot about that, thanks johnyb59!
Old Jul 17, 2009 | 06:40 AM
Mike D's Avatar
I know a couple of people who have put an HO pump on a SO engine without issue. What ill effects have you seen with regards to the software issue you talk about?
Old Jul 17, 2009 | 10:53 PM
DodgenIt's Avatar
Id stick with the SO (235)..
As I just learned the other day, The SO will cover down low AND up top while the HO will only take you so far power mod wise.
gitchyboy
Nov 22, 2011 05:03 PM
Sinbadd
17
Oct 20, 2007 10:56 PM
tyrod
Jan 28, 2006 05:51 PM
LarryLuana
Jan 28, 2006 05:10 AM
Mike67RS
Jul 24, 2003 06:59 PM
