2001 Data Link Plug???
this is crazy. i just upgraded my comp box to the juice with attitude, and do you think i can find the data link connector. right, its easy. sure. did a couple of searches. but does anyone have any picture on where it is or exactly what it looks like. i looked all arround my map sensor wireing, cant find anything. it it capped?/blocked?. in the install instructions. it says "some 2001 trucks the conector is located on the drivers side of the engine in the wireing harness near the powersteering pump." still cant find it. thanks.
Mine was lying on the lift pump bracket with a dummy plug in it.
maybe im looking to hard, i just cant find the darn thing. im reading my repair manual now, and found nothing yet either. argh!!! anything i read in the manual, tells me about the one under the dash.a picture would be nice if anyone had one.
Look just behind and just below the fuel filter canister. It can be on top pf the fuel filter canister as well.
ok, i have now removed my fuel filter, am i looking in the right place.
http://i102.photobucket.com/albums/m...D/DSC00685.jpg http://i102.photobucket.com/albums/m...D/DSC00687.jpg |
I found mine when I was putting in my Adrenaline box, On the drivers side at the front of the engine, about four inches below the VP-44 pump.
Larry |
3 Attachment(s)
here are a few pics that might help your in the right area i think your not looking low enough
On my 02 it was in front of the FF and down toward the bottom of the block, just above the oil pan. About in the middle (front to back) of the engine. It had a dummy plug in it for protection.
Destination... thanks dude!!! i found it, crammed in there, under old dirt and crap. ive been looking for hours, haha.. thanks for the images, the first one was the best.
no problem glad i could help
Mine is under the fuel filter
I found on my 02 the data link Connecter rite under the fuel filter. It is rite up against the block. Still installing my edge juice with attitude.
Here it is. Data link connector on my 02.
Gee thanks, now I'm going to have to hunt for mine. Probably never use, but I'm OCD about such things.
Clocks spring
Has anyone replaced a clock spring in an O2 Dodge if so do you need a special tool to pull-it
