2 wheel drive leveling kit
Old Sep 27, 2004 | 03:22 PM
Dieselcamper's Avatar
Does anyone have any tips or information on installing spacers in a 2 wheeldrive 2500 , to level the stance?
Old Sep 27, 2004 | 04:44 PM
apache's Avatar
Do some research and see if Moogs 3500 springs are stronger as in the early rigs. I would imagine you could add spacers if you can find them. Its bascially the same front end set up as a jeep cherokee and that is what lots use to raise them 2".
Old Sep 28, 2004 | 08:25 AM
gamiller31's Avatar
I put Daystar spacers in mine. I ordered them from one the vendors on this site, Don't recall which though. They are not really 2 inches, more like 1 3/4 inches, but they do make the truck look alot better. In order to install, upper ball joint must be disconnected. I changed upper and lower ball joints at same time, because they needed it. Stock ball joints have no zerk fittings, and after 75k miles they are shot.
Old Sep 28, 2004 | 02:29 PM
AZGEARPRO's Avatar
ball joints
How do you know when ball joints go bad on a 2wd?
Old Sep 28, 2004 | 07:55 PM
signature600's Avatar
I put 2-1/2" in mine, TOO MUCH! So I "shaved" them down to ~1-3/4", and it's almost perfect with the 1-3/4" I put in the back.
There is a pic of it loaded in my gallery, It gives you a general idea of how it looks
HTH,
Chris
Old Sep 29, 2004 | 12:06 PM
AZGEARPRO's Avatar
why was it too much of a lift?
Old Sep 29, 2004 | 02:29 PM
Oh nothing much, the nuts on the top ball joint was hitting the spring bucket, and had smashed the nut to about half of what it was. If you could get longer control arms, it would probably work perfect, but not without them!
And the shocks wouldn't reach, had a hard time finding shocks, but I did.
Skyjacker Hydro 7000's,
If you decide to do the lift, and want the part #'s, I can get them.
Any More Questions, Ask Away ,
Chris
Old Sep 30, 2004 | 06:18 AM
gamiller31's Avatar
AZGEARPRO - you can tell they are shot by raising one front wheel off the ground at a time, and while off the ground pull/push vigorously on top and bottom of tire and look/feel for any play, there should be none. However the easiest way to tell, is take it to an alignment shop, and get them to do a free inspection/estimate on the front end. They will tell you if something is wrong. By the way, the lower ball joints are very tough to change, and will leave you w/very sore muscles.
Old Sep 30, 2004 | 07:54 AM
hellotbone's Avatar
How level is this level enough? At least thats how I would have it :P
Old Sep 30, 2004 | 09:03 AM
Show Off
Old Sep 30, 2004 | 09:31 AM
hellotbone's Avatar
Old Sep 30, 2004 | 01:57 PM
SjLingenfelter's Avatar
Hey Bone,
How low does it sit with the bags aired completely down?
Old Sep 30, 2004 | 02:04 PM
hellotbone's Avatar
Your looking at it above thats it frame is on the ground.
L.J.B.
Jun 27, 2014 10:21 AM
joem
Sep 20, 2012 11:24 PM
sgtdiesel
25
Jun 26, 2012 02:37 PM
Txwelder
Mar 30, 2008 08:40 PM
97on22s
Feb 13, 2006 09:33 PM
