?????12v and 24v cams?????
Well I just bought a mechanical lift pump, and p7100 "914" pump
, and am now looking into putting a 12v cam in my 24v for the p-pump conversion and was wandering
if this would work is there a difference in the 2, other than the lobe for the mech. lift pump.
Thanks
Jake
if this would work is there a difference in the 2, other than the lobe for the mech. lift pump.Thanks
Jake
The 12v cam in a 24v motor will work if you time the cam correctly...... But it would be better and easier to install a F1 Helix cam. The cams come with a mechanical fuel pump lobe on them. You can find a description of the cams offered here: http://www.performancedieselwarehouse.com/850869.html
Doug
Doug
Originally Posted by signature600
What the heck is a "914?" Do you mean "913?"
I'd talk to F1 about the cam!
Chris
Chris
Im not looking to spend that kind of money for the f1 cam right now, maybe later.
Originally Posted by RonA
When you install the mechanical lift pump, don't forget that there is a .200 spacer between the pump and the block. It makes short work of the pump to forget the spacer.
jake
Originally Posted by cummnz4x4pwr
Pumps with numbers ending with 913 and up are the stronger of the 215 hp pumps.
Sounds like I should've done a bit more research before I bought my 913
Chris
Now I need to run out and look for a spacer LOL
Originally Posted by Rhino
I don't remember the spacer on my 1996 12v when I replaced the LP. Does this apply to the 24v blocks only?
