#10 and 3k
Old Aug 28, 2006 | 06:59 PM
dalee's Avatar
#10 and 3k
You can see by my post what i have now. Will switching to a #10 plate a 3k give me the same good low end,that 1400-1900 range because i spend 95% of my time there.
Old Aug 28, 2006 | 07:53 PM
crobtex's Avatar
You might get more response if you put this in the "12V Eigine and Drivetrain" forum.
Old Aug 28, 2006 | 08:42 PM
TxDiesel007's Avatar
IN comparison to a stock truck,
Your truck will be a night and day difference. The GSK will widen the normally narrow power band on your truck and u will be able to free rev the engine much higher than stock.
the ten plate in a stock position will really take that truck up a notch as well. U will feel it.
If you leave your timing at stock your low end power will be there, if you move it up to about 16-16.5 degrees, your low end will suffer a little bit, but ur fuel mileage will go up. Your power band will literally wake up at 1900 or so rpms and fuel hard with a 3K kit to about 3400 rpms...
Hope this helps
Rick
ON Edit: I misread your sig, your six plate should be more aggressive than the ten plate that you request. If you want more low end grunt, consider a starwheel, plate, and AFC adjustment. Make sure that your governer arm is also properly adjusted on the truck.. U might wanna check ur timing too
Rick
Old Aug 28, 2006 | 11:32 PM
cumminsdriver635's Avatar
Keep the 6, and do a GSK. You may have to adjust your governor arm, but you wont lose any low end doing that.
Eric
Old Aug 28, 2006 | 11:50 PM
displacedtexan's Avatar
I'm gonna third keeping your plate, and getting a GSK to widen the powerband.
sleeperman
Mar 8, 2011 02:56 PM
notpowerSTROKIN
42
Nov 10, 2007 09:02 AM
bigthumper
Aug 8, 2004 08:21 AM
Zino
Dec 16, 2003 05:19 PM
