View Poll Results: what do you think?
Hoss is da man, no
25
33.78%
Geico's question. He knows, yes
42
56.76%
your both wrong its a vto
9.46%
Voters: 74. You may not vote on this poll
will the plane fly?
Old Nov 28, 2005 | 10:02 PM
  #91
Geico266's Avatar
Originally Posted by gman07
Well if you won't admit that, will you AT LEAST admit that you don't actually have a concrete bedliner?
He doesn't?
Old Nov 29, 2005 | 05:42 AM
  #92
Tengu's Avatar
Originally Posted by rac156
I can't believe I just joined a forum to argue the physics of an airplane taking off from a conveyor belt. I must lead an exciting life.
Anyway to the question at hand:
The part of the question I believe to be tripping people up is "The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation."
We all know that this is impossible but for the sake of the question assume it is true. Also assume there is no slip between the wheels and conveyor and the conveyor always travels in the opposite directon of the wheels. The speed of the aircraft relative to the ground is equal to the speed of the wheels minus the speed of the conveyor. If the plane is to have a forward velocity then there must be a difference between the conveyor speed and the wheel speed. If the plane is to take off the difference must be equal to or greater than the take off speed. Given the problem statement "the conveyor belt is designed to exactly match the speed of the wheels" the difference in the two must be zero therefore there will be no ground speed. If there is no ground speed there is no lift. The plane will not take off.
As for the plane on skis argument, if you make the same assumption of zero slip they wouldn't take off either. The fact that the skis slide on the surface allows the plane to accelerate and eventually take off.
O.K. I am going to try ONE MORE TIME! Here ya go. All of the arguments about wheel speed are TRUE you are exactly correct except for one thing. The plane speed is INEDEPENDENT of the wheel speed. Think about it like this: The center of the wheel is not moving no matter how fast the wheel is spinning. When the plane engines start thrusting the thing that moves is the PLANE; it does not have ANY effect on the wheel speed. You could turn that conveyor up to 1,000,000 miles and hour and the plane would sit still (except for the very slight friction of the bearings. When the plane starts to move (Due to the thrust) it moves the only part of the wheel NOT ATTACHED TO WHAT IS ROTATING. Don't you see! AAAHhhhhhhggggggg.........
Old Nov 29, 2005 | 07:16 AM
  #93
rac156's Avatar
not true, plane speed is independent of wheel speed ONLY if there is slip between the wheel and the surface it is touching. In my statement previously I said to assume zero slip.
Old Nov 29, 2005 | 07:31 AM
  #94
Chrisreyn's Avatar
Have any of y'all thought about how hard Geico is laughing at all teh uproar and arguement this silly question has stired up????
Old Nov 29, 2005 | 08:12 AM
  #95
Geico266's Avatar
Shhhhhhhhhhh!
Actually this is quite interesting.
Old Nov 29, 2005 | 08:31 AM
  #96
Toto's Avatar
Can I have some of what you guys are smoking?
Old Nov 29, 2005 | 08:40 AM
  #97
pmtg's Avatar
OK, one more post on this one...
why do planes have turbines or engines to drive a compressor or propeller, when apparently they should be driving the wheels underneath the plane? how does that power get transferred to the wheels?
i work for this company...Cirrus Design
Old Nov 29, 2005 | 09:08 AM
  #98
Tengu's Avatar
For the love of God man! There will NEVER be any "slip" between undrivin! freely rotating! well greased! wheels. They have no power to them. The ONLY time that the plane speed itself is affected by the wheel speed is when the BRAKES are applied.
Old Nov 29, 2005 | 09:18 AM
  #99
gman07's Avatar
If you put a car in neutral and pull it forward do the wheels turn? When planes take off normally do the wheels turn? Sure, if the tires were sliding, the plane speed would be completely independent of the wheel speed. But as long as the frictional force between the tires and belt (or runway) is greater than the rolling resistance, the tires will turn.
Take a toy car. Put it on a sheet of paper. Have someone slowly pull the piece of paper backwards (hold the car in place with your finger). Watch how fast the tires rotate. Now push on the car with your finger so the car moves ahead slowly. Do the wheels speed up? Yes. Now try to get the car to move forward without speeding the wheels up.
This thread is getting old. I'm pretty sure people are going to believe what they want to believe.
Old Nov 29, 2005 | 09:30 AM
  #100
fozzy777's Avatar
OK if you had a sail boat with wheels on the bottom of it, and it sat on the same conveyor, with a 20 mile an hour wind. What would happen?
Old Nov 29, 2005 | 09:38 AM
  #101
gman07's Avatar
Provided its the same conveyor (the one that ALWAYS matches the speed of the wheels EXACTLY) the boat would go nowhere.
Old Nov 29, 2005 | 09:50 AM
  #102
rac156's Avatar
People will believe what they want to believe. I just like for people to believe what is right.
Lets look at it like this
the plane throttles up and begins to move forward. As a result of the plane moving forward the wheels turn (not as a result of being driven). The instant the plane moves the conveyor matches its motion in the opposite direction thus canceling forard progress. The pilot gives it more throttle and the plane again moves forward slightly and the wheels speed up. Again the conveyor instantly matches the speed and cancels forward progress. This pattern would continue and thus the plane would never gain ground speed as the conveyor is pusing it back as fast as it is trying to go forward.
given the same conveyor a sailboat on wheels would never move for the same reason as above.
Old Nov 29, 2005 | 10:56 AM
  #103
Hoss's Avatar
Thats MR Hoss to you buddy!
I'm glad that at least a couple of you have the intelligence to figure this thing out as I have. As I've said many times now, the plane will NOT take off.
  #104
fozzy777's Avatar
Ok if the plane was hanging by a string ( off the ground ), wouldnt that be the same as the conveyor? The plane would move.
Old Nov 29, 2005 | 11:05 AM
  #105
Hoss's Avatar
No, it wouldn't be the same. The force applied to the plane by the string would be in a different direction than the force applied to the plane by the conveyor.
As a side note, that would take one VERY strong string.
