Tool Box
Old Jan 25, 2011 | 04:43 PM
cbrahs's Avatar
I have the 45 gal combo from RDS. It was in my mega and I put in the the new truck. Got it plumbed for gravity feed in the filler neck. 80 gal fill up and run till dry
do you have a valve operated or is it completely gravity feed? I have a 100 gallon that i am installin in mine after the stretch and going to "add" onto that to get a "lil" bit more volume. am concerned about leakage around the canister. not worried about vent lines as they would be extended up to the top tank. everthing will be filled thru the top tank and the factory tank filler neck/door will be eliminated.
Old Jan 25, 2011 | 04:46 PM
Blake Clark's Avatar
I used this kit...
http://www.northerntool.com/shop/too...5501_200315501
Has a valve that can be shut off if needed. Has a float in the fitting to prevent overfilling.
Old Jan 25, 2011 | 04:48 PM
Must say though, on the 2011 (duallys anyway) the filler neck is all metal without enough hose to splice the t fitting into, so I found a metal 1/2 NPT fitting and used a hole saw to cut a 1/2 hole in the filler neck and welded it in. Then just put the valve into the fitting and plumbed it up.
Old Jan 26, 2011 | 07:44 AM
Mule Skinner's Avatar
Thanks for all of the replies, am sure I will find someone from these suggestions, cept for the cedar
Old Jan 26, 2011 | 08:00 AM
jerryleejr's Avatar
Just a thought I've seen replacement fuel tanks up to 67 gallons probably can find larger, if u wanted to just put a tool box in the bed.
JJ
Mkinner
Sep 21, 2010 07:57 PM
04ctd
Oct 5, 2006 08:27 PM
SBishop
Feb 14, 2004 05:21 PM
iwanactd
Dec 1, 2002 10:50 PM
