Stereo Upgrade Questions
Old Jun 27, 2003 | 12:17 AM
  #61
SjLingenfelter's Avatar
Re:Stereo Upgrade Questions
[quote author=Shovelhead link=board=10;threadid=16233;start=45#153787 date=1056666047]<br>Jamie, this Washington Post story outa be right up your alley.......DB Drag Racing<br><br>170 DB stereo systems!!!!!!!! <br>[/quote]<br><br>First time we went to show we hit 156db out of 2 12&quot;s Pushing 5000watts. 3000watts for the subs 1500 a piece. And 2000 watts for the mid's and highs.
Old Jun 27, 2003 | 03:48 AM
  #62
dodgeram's Avatar
what difference does it make what your pushing to the mids and highs when you're db dragging .......no way your note's that high <br><br><br>what class are you in street, superstreet or extreme ......<br><br>I'm in street .......<br><br>I was doing 148.6 @ 45hz with 1 12 inch beyond audio Inhuman and 700 watts in my reg cab 01<br><br>hit a 154.2 @ 52hz with 2 12 inch beyond audio x-ones and 1500 watts<br><br>I wanted my back seat back so now I'm downsized to 2 8's and 700 watts .......hit 138.2 @ 57 hz now <br><br> <br>I guess I'm getting old .......it doesn't need to be so loud anymore .........<br><br><br>anyways back on topic .........I'd just forget about the dash speakers put a component set in the front doors and a pair of coax's in the back ...........the JL's Jamie sugessted are nice speakers<br><br>before you buy anything hit your local shops and listen to as many different speakers as you can.........buy what you like......what sounds good to me may not be what sounds good to you <br><br>
Old Jun 27, 2003 | 03:55 AM
  #63
Dieseldude4x4's Avatar
Man, we got a little off the topic here I see. I don't think the original poster wants this much stereo. Some good reading here though.
Old Jun 27, 2003 | 09:02 AM
  #64
hellotbone's Avatar
Matt your idea will definately work adding an amp to the 6 speakers you plan on installing will definately make them sound better. Especially if you buy an amp with built in crossovers. Don't forget that the factory 6 speaker system in the trucks is also amplified so to achieve the sound you are looking for you will probably have to install an amp. For the sound you are looking for though you should not have to change the factory speaker wire your not going to be jambing on it like us guys.
Old Jun 27, 2003 | 10:27 AM
  #65
[quote author=BigBlue link=board=10;threadid=16233;start=45#153785 date=1056665724]<br>[quote author=SuperiorDiesel03 link=board=10;threadid=16233;start=45#153660 date=1056643875]<br>Ok Ill tell you.....<br>Its an Audiobahn AWT34X Linear Compression 34&quot; Sub<br>650oz magnet<br>5000 RMS <br>8000 Peak<br>88 db<br>5&quot; dual 2ohm voice coils<br>1 or 2 ohms depending on wire diagram.<br> ;D This is what the poeple that sponser us make. ;D<br><br>SD03<br><br><br>[/quote]<br><br>What do you think about one of those in my bed and using the whole bed as the box? Think I'll have to ever worry about being out thumped? <br>[/quote]<br><br>Ya if you want to spend the money on the sub &amp; the amp. Here's a pic of the amp.<br>1ohm mono 5000watts ;D
Old Jun 27, 2003 | 10:52 AM
  #66
[quote author=dodgeram link=board=10;threadid=16233;start=60#153980 date=1056703693]<br>what difference does it make what your pushing to the mids and highs when you're db dragging .......no way your note's that high <br>what class are you in street, superstreet or extreme ......<br>[/quote]<br> We were in 1st year amature. This year we will be going in as 4yr class 2 amature under stock radio. As for the mid and highs deal. It must be different where you are cause they measure all around thats why we hit so high. Plus the first year we used something that is not recommended. <br>Im just anoxiuos to see what we hit with tthis new setup.<br><br>SD03
Old Jun 27, 2003 | 11:12 AM
  #67
Matt400's Avatar
[quote author=dieseldude4x4 link=board=10;threadid=16233;start=60#153982 date=1056704107]<br>Man, we got a little off the topic here I see. I don't think the original poster wants this much stereo. Some good reading here though.<br>[/quote]Thats ok too cuz its kept my post up at the top! Man these dudes have some HDstuff.
Old Jun 27, 2003 | 11:19 AM
  #68
Cowhand's Avatar
I got a Craig AM/FM/8 Track powering an awesome 5&quot; paper speaker with a hole in it in the center of my dash. I got it at Pep Boys. It's really loud, like about 100dB at about 99% THD.<br><br>Chicks dig it. 8) 8)<br><br>BTW, does anyone know where I can get a hub adapter for a chain steering wheel? Will it work with the cruise control?
  #69
You got the HD stuff right for sure.
Old Jun 27, 2003 | 11:23 AM
  #70
Hoss's Avatar
Thats MR Hoss to you buddy!
How's this sound for a stereo system.......slip a George CD into the stock head unit and turn the **** to the right and hear that wonderful sound blow through the stock speakers?? ;D ;D ;D
Old Jun 27, 2003 | 11:28 AM
  #71
Matt400's Avatar
[quote author=Jamie Attridge link=board=10;threadid=16233;start=60#154044 date=1056722548]<br>Matt your idea will definately work adding an amp to the 6 speakers you plan on installing will definately make them sound better.[/quote]<br>I kinda figured that but now after bumping ideas off you I am thinking using the Pioneer HU you recommended, an amp and 6 really good speakers. Any recommendations on an amp and do you think the JL's you spoke of are still best &quot;with&quot; an amp or is another upgrade in order?<br>
<br>Don't want to do that if I don't have to but where do I stop upgrading? Gota draw the line here somewhere. I am gonna hold firm on no subs.<br>
Old Jun 27, 2003 | 11:30 AM
  #72
Redleg's Avatar
I took my door skins off to make the speakers louder... now I get the sound from the front AND the back. If I don't have a passenger, I slide both speakers beind the seat to my side to make it real loud.
Old Jun 27, 2003 | 12:04 PM
  #73
Cowhand's Avatar
That's what I'm talkin' bout. George sounds great on my speaker....
Old Jun 27, 2003 | 12:23 PM
  #74
Matt400's Avatar
[quote author=Hoss link=board=10;threadid=16233;start=60#154096 date=1056730989]<br>How's this sound for a stereo system.......slip a George CD into the stock head unit and turn the **** to the right and hear that wonderful sound blow through the stock speakers?? ;D ;D ;D<br>[/quote]Thats whats been workin, maybe if it aint broke don't fix it!?
Old Jun 27, 2003 | 12:26 PM
  #75
Matt400's Avatar
[quote author=Cowhand link=board=10;threadid=16233;start=60#154092 date=1056730795]Chicks dig it. 8) 8)[/quote]<br><br>What kinda chicks we talkin here?
