Stereo Install Help
Old Sep 16, 2003 | 10:19 PM
Gonzo's Avatar
Stereo Install Help
I'm trying to find a schematic of the wiring on the Delco radios that were put in the 2003 GMC Sierra. It is an RDS unit and has a what looks like a 24 pin connector, 2 rows of 12.
I'm adding a low level line input converter and have no idea what the wires are,,none are marked.
Old Sep 16, 2003 | 10:31 PM
phox_mulder's Avatar
Re:Stereo Install Help
Check the actual manufacturer plate on the back.
Hopefully even a model number.
I had to find a diagram for my moms radio in preperation for installing a replacement, so I could just use the original power/ground and speaker wires.
Went to the manufacturers web site and was able to find a model number close enough that the plugs matched.
They didn't list the actual model number, as it wasn't available aftermarket, made exclusively for OEM application.
Till someone else chimes in, worth a shot.
phox
Old Sep 16, 2003 | 11:16 PM
BigBlue's Avatar
From what I've been told about the GM radios, they are an absolute nightmare to work on.
Old Sep 17, 2003 | 06:20 AM
dodgeram's Avatar
you can check this
http://www.installdr.com/Harnesses/GM-Wiring.pdf
I don't think the newer trucks is in there though
I asked around one installer told me you probably have the bose radio and will need an adaptor
he said to use the C2A-GM24 from PAC
http://www.pac-audio.com./
I have no idea what that is , but ask around at some local install shops they should know
Old Sep 17, 2003 | 06:31 AM
Dieseldude4x4's Avatar
You can go to http://www.crutchfield.com/ and find a phone number if need be. They will actually talk to you and help you out.
Old Sep 17, 2003 | 07:41 AM
hellotbone's Avatar
the12volt.com
BKCBUILDER
May 18, 2006 05:58 AM
juice
31
Jan 18, 2006 03:09 AM
fahlguy
Nov 27, 2004 09:16 AM
glowball
Mar 6, 2004 06:48 AM
