Septic tank trouble?
Lately one of my toilets has started to burp...(like its saying...ummmm good)
when the other commodes are flushed or water is run from somewhere else in the house. Its always the same one but I have a shower upstream of it and I don't have any problems with it draining. The toilet is also slow to flush(most of the time) and sometimes won't flush at all. Does this sound like septic problems or just a problem with that one toilet?
Well, I had woodpeckers FILL two 2" vent lines with acorns. Had to cut them off under the house and in the attic and extract the debris with a shop vac and fish tape. Now the vents have hardware cloth screens and metal pungy sticks sticking up to poke the little dudes.
Could be a problem in that particular stool.
Is it slow flushing solids and liquids? If it's flushing, but real slow, it could be someone dropped something into the stool. Could be a plastic container of anything.
Here's a easy, simple solution to check if something is caught in the stool and can't get past the bend. Turn the water off at the shutoff at the stool. Flush the stool to drain the tank. Bail as much water out of the stool as possible with a plastic container like those round butter containers butter comes in. Then insert a 2" shop vac hose into the stool and wrap with a rag to keep air from leaking in around to the vac hose. Turn it on. It will suck up just about anything that won't make the turn in the stool, and quickly!!
