Separation Anxiety
Separation Anxiety
I finally went and did it: Dropped my truck off at the shop to have my Valair clutch installed. Normally I don't pay anyone to do work I'm capable of performing on my own, but I just don't have the garage space or jacks required to do it safely and properly by myself. Problem now is that I'm worried about the job they're going to do, and I find that I really, really don't like it when someone else works on my truck...
Thought I'd share my anxiety for those who feel the same but aren't able (or willing) to share.
Maybe I'm just a little too attached to my truck...
Okay; probably not, but at least I've got a great support group!
I was lucky. The only time mine has been in was for part of a day and I was able to look through the garage door to see what was happening. They wouldnt let me stay in the truck drinking beer like I wanted.
When my truck is in the body shop I am there visiting it every day like having a patient in a hospital.
I stay out of their way so I do not annoy anyone, he is also cool with me taking pictures while it is in the shop.
Try and keep yourself busy, it will help to keep your mind off your truck and time will go by faster.
Jim
Jim
I'm fortunate here in San Diego to have a local shop that prides itself on doing the job right. One tech in particular is a perfectionist. Mine's in there right now awaiting some shocks that Thuren's revalving for me.
www.ntgracing.com. I highly recommend them.
My clutch is next. ouch!
I feel like that when I have to let the wife use the truck, and I stand outside watching my truck drive away. When she's finally out of sight, I go back in the house and worry! I pretty much need to be sedated whenever I have to leave the truck with others, for work that I can't do myself!
Got her back about two hours ago...No leaks, drips, or oil runs; interior clean; floor mat shield used; seat returned to my position; radio NOT turned to crappy radio station and left on ear-bleed level. 45 minute shakedown run and everything seems good to go...
When I got there their diesel tech was in the lobby and I talked with him for awhile. He's a Ford guy, but understands diesels and I feel pretty good about his experience and attention to detail, so that's a relief. Plus; if he can keep a 6.0 running well, he's got to have some skill somewhere
I'm not feeling completely safe yet, but so far so good.
Now it's time to turn the Smarty down and properly break-in my clutch...
Adam,
This will make your anxiety go away completely. I was going to replace my clutch myself, but ended up letting a dodge dealer do the work. Well, I got the truck back and everything seemed fine. They replaced my rear main seal also. Well, after 50k it's leaking again. I got 199K out of my first one. So I removed the transmission myself and removed the seal. The crankshaft journal had a groove in it and they just stuck another seal on there. Why don't technicians work on vehicles like they own it? That crank should have had a wear sleeve installed to prevent this. 700.00 in labor right down the drain. Never again! Do you still feel bad?
Last edited by 6spd05Dually; May 28, 2011 at 02:36 PM. Reason: spelling error and update
