Remving road tar ...
I was travelling down a dirt road this morning and hit a patch of chip and tar that must have been done that morning. There was no road signs or anything, it was done in front of one house only. I now have tar splatter down both sides of the truck and I can't get it off, trying some cheap bug and tar remover worked some but there's too much. [verymad] [verymad] [verymad]
Anyone have any good solutions?? Anyone every get compensation from the local township for such crap?? |
WD-40
if something needs to stay, you use duct tape
if something needs to move, you use WD-40. Plain, simple rules of life. |
sorry but you won't get compensation from the engineers/road crew office. i work for the engineers office and we get complaints ALL THE TIME about road paint, black top, etc etc... today we were out painting and some woman drove her new bmw through wet paint and called and complained... we just laugh, work has to get done...
i guess i shouldn't say you won't get compensation, it may differ from where you live but doubt it... :rolleyes: good luck but yea use WD-40... |
I've used Turtle Wax Bug and Tar remover before. Works great, just follow the instructions.
~Rob |
~Rob |
IMHO I wouldn't use gas because whatever you use will get all over you and gas hangs in ther for the long haul. If WD40 is fast enough and you are not afraid to reapply the wax, which you probably will do anyway,try acetone. Try it first some where that is not noticable to see what it is going to do to yyour paint. Use proper gloves. It will remove all the oil from your skin. Only use it in a well ventallated area, preferably outside FAR away from any ignition source. I have used it with great success removing glue from the top of the bed where the velcro was attached and it did not remove the paint. But the wax..........
Straight butyl is the best degreaser/emulsifier, but you may not be able to get your hands on it. I had one of our chemical manufacturers supply us with a 55 gallon drum a couple years ago and I still have 7/8 of that drum. It is also great at removing the soot off of bumpers and lower rear of the bed.
Try some diesel! Spray it on or soak some rags and start wipin'.
WD-40 works but sometimes I run out and plain-ol' diesel works fine as long as it hasn't been on there for 3 years. K. |
AVON Skin So Soft...
Avon Skin So Soft works great just don't let your wife catch you using it..it's a little pricey, but in a pinch it works great. Doesn't take much, just put a small amount on a soft clean cloth and dab it onto the heavy spots first, then wipe down al the other areas, wait about 5 mintues and start rubbing it off. Leaves a nice shine and won't take off the wax. good luck. :)
I use diesel. My dad used to haul paving asphalt many many years ago. Thats what we used to clean the inside of his end dump trailer. It worked good then and works good now.
I mean what possessed you to try Skin So Soft in the first place? Was it a stroke of genious or shear insanity? Of all the chemicals in my garage (and Skin So Soft isn't one of them), I never would have thought to try that. Curious, ~Rob |
How do you know that?? [laugh]
