PE Exam
Originally Posted by hotdram
PE???
You guys are still taking gym class ?
Engineers are nerds
Good luck guys!!!!
~EERob
Engineers are nerds
Good luck guys!!!!
~EERob
yea, we may be nerds, but we also design bigger bombs.
Yeah, we are nerds.
I know a little about building bombs and their components.
Not too big, but I did the power supply in this guided munition:
~Rob
roads and commodes. Do you have to do a calculation on how fast porcelan warms?
Graphite,
It sounds like we are in opposite boats. I also have a civil degree, but also a master's in civil with a structural emphasis. Most of my experience is in structural design of all types of buildings. I had a brief stint in Geotechnical that only lasted a few months
NCEES website says bridges will make up approximately 20% of the S1 exam. Like you said, codes are like night and day from buildings to bridges. Figuring out the design loads on bridges a real PITA. I'm just going to study the component design (mainly stringers and deck) and hope for the best. I'm good to go on the other structural areas.
Good Luck,
Brad
.NCEES website says bridges will make up approximately 20% of the S1 exam. Like you said, codes are like night and day from buildings to bridges. Figuring out the design loads on bridges a real PITA. I'm just going to study the component design (mainly stringers and deck) and hope for the best. I'm good to go on the other structural areas.
Good Luck,
Brad
Originally Posted by bamadzl
Graphite,
Good Luck,
Brad
Good Luck,
Brad
The best advice I can give you on deck/beam design is to not forget the impact factor, the distribution factor and the continuity factor. If they give you a truck load, have fun.... unless you know how to calculate the maximum design moment from 3 different point loads on a simple span, you'll just bang your head. The CERM has a good example though.
Yeah, if I get a truck load I'm going to guess immediately. If I get design moments I might give it a shot. I think I can get the slab/deck designed, though. I have a "Bridge Engineering" text from a class I took that has some decent design examples.
Thanks for the advice
Brad
Brad
How did you guys do??
