Non-mobile Mobile C B Antenna ???
Old Nov 15, 2008 | 12:14 AM
BearKiller's Avatar
Question Non-mobile Mobile C B Antenna ???
Is it possible to rig up a vehicle C.B. antenna on my shop, either inside or out, for the purpose of testing/tinkering with some of the multitude of C.B.s I have accumulated from swap-meets, truck-swaps, dog-trades, etc.
I keep a spare GROUP-31s in the shop for 12-volt power.
I just need something rigged up so that I can bench-test a C.B., in order to determine if I want to simply install it in a truck, maybe send it to the shop, or cull it to the parts pile.
Can the antenna work as a stand-alone, with maybe a ground-wire from antenna-base to C.B.-housing to NEG-post on the battery ??
Or maybe the antenna mounted in the center of a grounded sheet of metal ??
Ideas please.
Thanks.
And NO, I do not want, nor can I afford, a fancy base-station antenna outside on a tower.
Old Nov 15, 2008 | 12:35 AM
Alwaysworking's Avatar
alwaysonDTR
my grandpa's garage has a normal magnetic base antenna the hooks to the CB then the CB gets power from the batt.
Old Nov 15, 2008 | 07:02 AM
donnee's Avatar
I had a Radio Shack mag mount on a metal cabinet in my garage.
The cb was powerd by a converter.
Seemed to work fairly good.
Didnt get a whole lot of range with it but it was nice if the DW had to contact me for any reason.
Old Nov 17, 2008 | 05:25 PM
BearKiller's Avatar
Thanks for the replies.
The roof is metal; I guess if I get a long enough co-ax, I can just stick a magnetic base up there; if the cord is too short, then I will just stick one on the filing cabinet.
Will it be beneficial to also run a ground-wire from whatever metal surface the antenna sticks to to the negative post on the battery ??
Old Nov 20, 2008 | 08:59 AM
donnee's Avatar
I believe that if you put a mag mount on a cabinet in the shop, it will suffice for grounding purposes.
Patrick Campbell
Jul 11, 2003 06:20 AM
clifford
May 11, 2003 05:18 PM
BigK
Jan 26, 2003 12:58 AM
TPilaske
Dec 15, 2002 03:24 PM
