need help finding a pressure regulator
Old Apr 22, 2006 | 10:26 AM
Captain's Avatar
I'm putting onboard air into my truck. The pressure switch is set to turn on at 100psi and off at 125psi. I also have an ARB locker in the front diff that require something like 80psi or so to run and to much more will apprently blow out the seals in it. I need to drop the pressure going just to the air locker. The problem is most regulators I'm finding in store and online are very intollerant to temperature and vibration. Most have a temp range of say 45-150degrees. Since this is mounted in the engine bay it has to be good to at least 0 or -20. Does anyone know of where to look for such a thing? Or better yet is there a non-adjustable type regulator. Something wtih no gauges or any of that. Just plug in air on one side and it comes out at a set PSI on the other end? If such a beast exsists that would be the best but im not sure what it would be called to search online for it.
Thanks again all.
Old Apr 22, 2006 | 10:30 AM
MikeyB's Avatar
How about this one?
http://www.omega.com/pptst/PRG101.html
MikeyB
Old Apr 22, 2006 | 10:45 AM
Fronty Owner's Avatar
We use watts brand at work for our pneumatic equipment. They have some rather small regulators that may be more what your looking for.
Old Apr 22, 2006 | 11:56 AM
Captain's Avatar
first off id like to say that that pgr101 is the best thing ive seen so far. I'll check out watts now. Thanks guys apprciate it.
ramguy
May 27, 2003 10:48 AM
Skyking650
Feb 9, 2003 06:40 PM
Skyking650
Jan 11, 2003 11:02 AM
Hauler
Dec 12, 2002 10:48 PM
