Need Help
Old Feb 23, 2007 | 10:40 PM
jbjarko's Avatar
Need Help
I am helping my buddy instal some lowering springs on his 06 accord. I know, should be shunned upon, but we need help. I got the pinch bolt out of the fork, the three nuts off the top of the strut, but I can't get the strut assembly to drop out. Do I need to take off the rotor as well? In addition to the three nuts on the top of the strut, there is a center bolt as well, does that need to be taken off? Were at a loss. Thanks.
Josh
Old Feb 23, 2007 | 11:19 PM
ofcmarc's Avatar
There should be a slot around the lower end of the knuckle that the pinch bolt squeezed. Take a chisle and drive it in the slot a ways to spreat the hole for the strut. You shouldn't have to remove the rotor but probly need to get the CV axle out of the way to get a little more roome to work the strut out of there.
DO NOT remove the center nut from the strut until you have the spring caged in a strut spring compressor. Probly can't get it off like that anyways but if you did Watch out! big heavy spring flying wildly
Old Feb 24, 2007 | 12:23 AM
jbjarko's Avatar
Yea, I finally got it all figured out. There were two EXTRA hidden bolts at the top that were holding it on. Thanks..
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
