this made me smile...
Old Mar 11, 2003 | 11:50 PM
westcoaster's Avatar
[Editor's Note: Occasionally, while analyzing systems for criticality safety evaluations, we run into some odd-ball equipment, process, or methodology that we can only trace back to "that's the way it's always been done" or looking at a "crazy" design, we'd exclaim "which horse's *** designed this?" (Younger engineers would exclaim "what the (censored)" but the intent is the same.) Bearing this in mind, we thought you'd enjoy some perspective on why the Space Shuttle's solid rocket boosters are designed to a certain size. The story starts with the railroad.]
The US Standard railroad gauge (distance between the rails) is 4 feet, 8.5 inches. That's an exceedingly odd number?!
Why was that gauge used? Because that's the way they built them in England.
Why did the English people build them like that? Because the first rail lines were built by the same people who built the pre-railroad tramways, and that's the gauge they used.
Why did "they" use that gauge then? Because the people who built the tramways used the same jigs and tools that they used for building wagons, which used that wheel spacing.
Okay! Why did the wagons use that odd spacing? Well, if they tried to use any other spacing the wagons would break on some of the old, long distance roads, because that's the spacing of the old wheel ruts. So who built these old rutted roads? The first long distance roads in Europe were built by Imperial Rome for the benefit of their legions. The roads have been used ever since then.
And the ruts? The initial ruts, which everyone else had to match for fear of destroying their wagons, were first made by Roman war chariots. Since the chariots were made for or by Imperial Rome they were all alike in the matter of wheel spacing. Thus, we have the answer to the original questions. The United States standard railroad gauge of 4 feet, 8.5 inches derives from the original specification for an Imperial Roman army war chariot. Specs and Bureaucracies live forever. So, the next time you are handed a specification and wonder what horse's *** came up with it, you may be exactly right. Because the Imperial Roman chariots were made to be just wide enough to accommodate the backends of two war horses.
When we see a Space Shuttle sitting on the launch pad, there are two big booster rockets attached to the sides of the main fuel tank. These are the solid rocket boosters, or SRBs. The SRBs are made by Thiokol at a factory in Utah. The engineers who designed the SRBs might have preferred to make them a bit fatter, but the SRBs had to be shipped by train from the factory to the launch site. The railroad line to the factory runs through a tunnel in the mountains. The SRBs had to fit through that tunnel. The tunnel is slightly wider than a railroad track, and the railroad track is about as wide as two horse's behinds. So a major design feature of what is arguably the world's most advanced transportation system was determined by the width of a horse's ***.
Source: amsat-bb@AMSAT.org email from Clifford Buttschardt received on Wednesday, September 22, 1999 5:19 PM
I found this on another site, I got a chuckle out of it...
Old Mar 12, 2003 | 08:55 PM
Redleg's Avatar
Re:this made me smile...
If the distance between the rails is 4'-8.5", could the outside-outside be 5'? Foot and a half on both sides for ballast would be 8', a standard dimension for lumber. Just guessing on dimensions here.
Old Mar 12, 2003 | 09:19 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Go to www.snopes.com and search for Horse's As*
Old Mar 12, 2003 | 10:12 PM
dodgeman01's Avatar
you guys missed all the fun. I thought it was funny.<br>DM01
Old Mar 13, 2003 | 10:49 AM
BIG&BAD's Avatar
that was pretty funny
Old Mar 13, 2003 | 11:10 AM
BigBlue's Avatar
I've read that before.
13ALPHA
May 16, 2007 10:45 PM
Mexstan
Jan 17, 2004 01:29 PM
AKDSLDOG
Nov 7, 2003 07:55 PM
Mexstan
Jun 25, 2003 07:41 PM
