Internet Connection Speed Test?
Old Feb 18, 2005 | 08:50 PM
phox_mulder's Avatar
I haven't tested mine since I switched over from Sprint Wireless Broadband to ADSL
Communications 2 megabits per second
Storage 241.5 kilobytes per second
1MB file download 4.2 seconds
Subjective rating Great
Tested at the Bandwithplace.com.
Sprint BBD was faster download but upload was slower than dialup.
Cable isn't quite out here yet, so I had to settle for DSL.
phox
Old Feb 18, 2005 | 09:03 PM
budsowner's Avatar
Originally posted by SN0WMAN
Loaded 754,928 bytes in 46.617 seconds from Polar Comm. server
from that toast.net
When go to the link i posted go to the left to the more tests and select the shuttle and as the host select the toast.net.It gives sa little better test .
Old Feb 18, 2005 | 09:05 PM
budsowner's Avatar
Originally posted by wv smoker
Ditto on the Toast.net, that's the one the Charter guys usually use around here.
Yes i got that from charter guy and direcway installers use the same one.
Old Feb 18, 2005 | 09:23 PM
SN0WMAN's Avatar
Loaded 1,396,595 bytes in 477.436 seconds from Go Daddy server....the jet fighter one
and
Loaded 414,161 bytes in 13.829 seconds from TOAST.net I server.....the shuttle .
......hate havin dial-up as only option
Old Feb 18, 2005 | 09:34 PM
spunbearing's Avatar
2wire.com and bandwidthspeedtest.com are both good testing sites.
Old Feb 18, 2005 | 09:56 PM
bulabula's Avatar
Verizon DSL:
Communications 1.5 megabits per second
Storage 187.3 kilobytes per second
1MB file download 5.5 seconds
I'm waiting for fios to arrive ...... then I'll do VOIP and drop the land line.
Old Feb 18, 2005 | 10:16 PM
jlells01's Avatar
"F-16 Fighting Falcons Test Results
Loaded 1,396,595 bytes in 0.953 seconds from Nibble Info Systems server."
Old Feb 19, 2005 | 02:21 AM
4doogie's Avatar
1.1 megabits per second
Communications 1.1 megabits per second
Storage 138.7 kilobytes per second
1MB file download 7.4 seconds
Subjective rating Good
ON THE WIRELESS, LAPTOP
Old Feb 19, 2005 | 07:01 AM
Pentastar's Avatar
I like this one...........a great big speedometer with references to the typical speeds for your type of connection.
I have *** cable and we are almost T2 here in Connecticut.
http://us.mcafee.com/root/speedometer/default.asp
Here is the speed I just got..buried the speedometer.....3.706 MB per second
http://us.mcafee.com/root/speedometer/test_0600.asp
Old Feb 19, 2005 | 07:19 AM
Shovelhead's Avatar
Administrator / Scooter Bum
File Size: 150.005 KB
Time Elapsed: 1.562 seconds
768.24 Kbps
(96.03 KBps)
Old Feb 19, 2005 | 08:48 AM
mikmaze's Avatar
10.4 megabits per second
Communications 10.4 megabits per second
Storage 1.2 megabytes per second
1MB file download 0.8 seconds
Subjective rating Unbelievable
not a fluke, this outa NY server:
Loaded 754,928 bytes in 0.578 seconds from Host Rocket server.
I have found out the hard way, do it again right this time, that the cheap splitters are exactly that, cheap. If you are running cable you should get the best splitter you can find, one half goes as short apossible with good cable directly to the cable modem. The second split feeds the rest of the house, again for best results for reception good splitters and cable to the sets. If you have poor tv quality you may be able to find a signal amplifier at home depot to push that signal along. The one I got is a 25dba signal amplifier. Do not place this type of unit before your cable modem!!! It is to be installed on the split that feeds the hous tv's, again, not the modem!!! This unit cleared a problem I had and is amazing the difference it makes. Hope you all find this helpfull.
Old Feb 19, 2005 | 10:36 AM
t-15 firefighter's Avatar
DTR's Self Appointed Beer Advisor
Results from Bandwidth Place
Communications 4 megabits per second
Storage 484.2 kilobytes per second
1MB file download 2.1 seconds
Subjective rating Awesome
Results for Toast.net
Loaded 340,781 bytes in 0.703 seconds from Nibble Info Systems server.
Results for Mcafee
Your Internet Connection
Speed Results
File Size: 600.005 KB
Time Elapsed: 1 seconds
4.688 Mbps
(600 KBps)
Speedometer reads over 2MbPS T-2 but I doubt that.
This is running 3 computers and 1 XBOX through 1 wireless network router. This computer is hooked directly to the router. Don't know if that makes any difference.
Britt
Old Feb 19, 2005 | 12:24 PM
jlells01's Avatar
Communications 13.3 megabits per second
Storage 1.6 megabytes per second
1MB file download 0.6 seconds
Old Feb 19, 2005 | 01:56 PM
WOW!
britt
Old Feb 19, 2005 | 03:46 PM
jlells01's Avatar
"Connections over 8mbit/s are not supported."
I don't think it's too accurate...
Seriously though, I was testing out at about 8mbit/s when using Mozilla Firefox. I bought into all the big-time hype surrounding this browser and was throughly impressed with it's tabbed browsing and supposed security features, but it was just too slow and didn't work properly on several sites I frequent.
Using good anti-virus and firewall programs, I've had no issues at all with Avant, which uses the base IE program, but adds tabbed browsing!
Here's a screen capture
