I'm back in the light!
Old Dec 7, 2011 | 08:58 PM
LUKE-MM-PULLER's Avatar
I just bought a 93 with over 300k on the clock! It's got some issues so I'm gonna need all the help you guys can offer!
1. The overdrive hasnt worked for 8yrs.
2. Speedometer dont work.
3. powersteering and brakes suck.
4. steering wheel is sloppy but all knuckles and joints are good.
5. the voltage meter meter bounces and headlights flicker.
Old Dec 7, 2011 | 09:05 PM
chaikwa's Avatar
Let me see if I can help...
It is broken.
That is also broken.
Those are GOING to break.
Frame is probably cracked, (broken), behind steering box.
Something is loose and if you don't fix it, it will be broken too.
Did I help?
Seriously tho, I loved my 93. And the broken frame I mentioned happened on mine, which is why I mentioned it. The overdrive COULD be an issue with the TPS. They are known to
Old Dec 7, 2011 | 09:18 PM
bkrukow's Avatar
Sounds like a project truck. Are you still in Sheldon or did you get moved? I havent seen ya around town in your DMax lately so I asumed ya got moved.
Old Dec 7, 2011 | 09:25 PM
Yeah that helps! I've got a good idea about alot of it except the overdrive problem. figured the regulator in the alternator is bad since its the original. the steering box is very sloppy, but I'll check the frame to. The brakes are very soft. I'm looking for opinions, all opinions!
Old Dec 7, 2011 | 09:28 PM
I'm still in Sheldon bkruckow, I sold the DMax last week. Yeah its gonna be a PROJECT till its ready to be a daily driver.
Old Dec 8, 2011 | 06:59 AM
chaikwa's Avatar
I believe the regulator in that year is a part of the ECM. I've heard a lot of the guys here talking about installing an external regulator in order to avoid replacing the ECM. When it happened in mine tho, it was the wire that ran from the alternator to the ECM. It had an intermittent break right behind the windshield washer tank.
Old Dec 8, 2011 | 07:10 AM
Totallyrad's Avatar
Manually adjust the rear brakes and see if that brings them up. I wish I would have known you were looking for a project truck.
Old Dec 13, 2011 | 11:28 AM
brainfade's Avatar
Ahem. You may not have noticed, being all fancy with the 98.5 and everything, but there's a whole forum (tucked away in a dark corner) where all your questions can be answered. All these over-valved, coil springy guys are going to do is give you a bunch of hoo-haw.
Walk towards the light...
Old Dec 13, 2011 | 05:46 PM
Ok brainfade show me the light an give me your solutions for problems!
Old Dec 13, 2011 | 06:40 PM
JD730's Avatar
Overdrive needs a few things in order to work, the PCM needs a signal from the speed sensor and a signal from the TPS.
This is most likely the speed sensor or parts that are related to the speed sensor like the speed reducer adaptor.
Old Dec 14, 2011 | 02:24 PM
SIXSLUG's Avatar
Yep, its a Dodge!!
Old Dec 14, 2011 | 05:31 PM
Awsome JD730! now I now where to start. I'm starting to think the PCM has some issues cause the volt guage goes all sorts of crazy to.
Old Dec 15, 2011 | 07:13 AM
12valve@heart's Avatar
That (and some of the other issues) could be related to a bad ground. Not uncommon on the 1st gens. Might be the cheap place to start.
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
mr T
Feb 24, 2007 06:42 AM
JoshPeters
Apr 3, 2005 08:13 AM
Rumbles
May 24, 2004 02:26 PM
